X2
A couple of answers are increased rocker arm ratio and asymmetrical cam lobe design.randy331 wrote: ↑Tue Mar 12, 2019 11:00 pm For the vast majority of engines that have physical limitations on lifter diameter, journal diameter, etc, how do you just "cam it right" for improved low lift flow ?
How do you keep the time/area up top if you just keep improving low lift flow and taking duration out to compensate?
Lift becomes a limit as duration goes down.
The problem is, we are always confronted with the choice of best compromise. The valves don't have unlimited motion. We are always confined by the architecture of the engine, class rules, budget, etc.
The best cam for a certain application isn't a perfect cam, it's just the best compromises.
There are other reasons steeper seats are used than the flow we see on a bench.
So far the thread has been for the most part very civil even though there has been disagreement on ideas,...as it should be.
For the few that think this thread had some sinister motive to go down a certain path and have nothing to contribute,... read other threads and stay out.
I've used the phrase "optimize the compromise" recently for this reason, especially when it comes to street/strip combinations like my own.randy331 wrote: ↑Tue Mar 12, 2019 11:00 pm
The problem is, we are always confronted with the choice of best compromise. The valves don't have unlimited motion. We are always confined by the architecture of the engine, class rules, budget, etc. ...
Well, stop playing with engines that have crap valvetrains! That's in jest, but it's obvious that there's always limitations that prevent "ideal" scenarios. My problem with making a blanket statement along the lines of "too much low lift flow is bad for power" is that it's wrong. On a very specific engine application it could prove true due to other factors outside of flow such as combustion quality, valvetrain limitations, etc. That's not the fault of the increased flow itself, it's the fault of the specifics of the combination.randy331 wrote: ↑Tue Mar 12, 2019 11:00 pm For the vast majority of engines that have physical limitations on lifter diameter, journal diameter, etc, how do you just "cam it right" for improved low lift flow ?
Some DV art to add to conversation.
It's not surprising given the valve job they had when I got them.
I was just running your flows through Rick's Curtain area program, very pronounced increase in window DC at all lifts.randy331 wrote: ↑Wed Mar 13, 2019 10:35 amIt's not surprising given the valve job they had when I got them.
It really was a horrible valve job. Big edges around the top cuts in the chamber etc.
A better 45* and or cleaning up around the horrible one they had would have made them flow more under .300, then you'd see a more normal change going to 50* seats. But I don't bother flowing them in stages of porting.
That's why I pointed out earlier that you have to reduce low lift flow correctly. Just screwing shit up to reduce flow anywhere is always a bad idea.
As in, "Take my Stage VI head... please!" (spoken w/ a Rodney Dangerfield impression)?ClassAct wrote: ↑Tue Mar 12, 2019 2:44 pm ...
Take the Chrysler stage 6 head. What a piece of shit that thing is. Period. To make them work, you do many things that are considered wrong. They will make power, but the flow numbers never look like they should. In fact, if I see what I consider big numbers for that head, I know it's wrong. Fixing it will certainly reduce flow across the bench. But they will always be quicker in the car, and if you pay attention you'll see the BSFC numbers are better.
You have a problem with blanket statements?LoganD wrote: ↑Wed Mar 13, 2019 8:55 amWell, stop playing with engines that have crap valvetrains! That's in jest, but it's obvious that there's always limitations that prevent "ideal" scenarios. My problem with making a blanket statement along the lines of "too much low lift flow is bad for power" is that it's wrong. On a very specific engine application it could prove true due to other factors outside of flow such as combustion quality, valvetrain limitations, etc. That's not the fault of the increased flow itself, it's the fault of the specifics of the combination.randy331 wrote: ↑Tue Mar 12, 2019 11:00 pm For the vast majority of engines that have physical limitations on lifter diameter, journal diameter, etc, how do you just "cam it right" for improved low lift flow ?
If low lift flow is bad, then why do 4-valve heads make so much more power?
A 2v head probably makes more power if both are done to meet the piston demand the engine requires ie same flow at peak valve lift
How many extra flows would you need with a 45° seat to equal or better the window DC of the 50° seat at all lift points?
