before/after 383 dyno results
Re: before/after 383 dyno results
[attachment=0]5748009011.jpg[/attachmen
Unrelated but: An engine I built circa 2000 headed to dyno..look at all the room i had left over for more carbs and adapters.
Any thoughts as to why this 13.1 engine was no better than your 11.1 Fast Burn head 383?
Some of this info would be more easy to compare with actual dyno sheet vs a graph or just numbers on a spread sheet but then again I am just repeating what you guys say.
The cam was moved. Advanced it 3* from 110* to 107 and it was a very small loss. I felt safest as far as valve to piston clearance at 108.5, so that's where it went after moving it and where it currently is.
It had no vacuum pump on it before, but he was ok with the cost, so it does now. Looks like head work and cam change, .020" tighter quench, and lower tension oil rings was worth about 80-85 of the HP. Q16 and vacuum was the rest.
The previous need for 48* was a combination of things. Piston to head (quench) too much, retarded radiused intake seats, the 105 LSA cam, too big of header to make the other problems worse. It ex residue in the intake manifold. EGR increases the needed timing.
Well,.... don't remember doin lotz of specin for you,.... well,... other than specin breakfast at Zadocks that one time.
CGT...how did that engine work out with the TR and 2bbls? I've always wanted to try a set up like that because it would seem to me like it would reap the benefits of the better intake entry the TR has and you wont need jet extensions...lol.
What was the fuel and vacuum worth each?randy331 wrote: ↑Tue Apr 16, 2019 10:44 pmThe cam was moved. Advanced it 3* from 110* to 107 and it was a very small loss. I felt safest as far as valve to piston clearance at 108.5, so that's where it went after moving it and where it currently is.
Can you post the dyno sheets showing each of these changes so we can evaluate what you did?
I looked back through the posts and found the original cam specs...was the new cam posted? I could not find it.
Randy,randy331 wrote: ↑Tue Apr 16, 2019 7:23 pmThey are a decent head. If one is buying heads and wanting a wider pushrod area I'd buy the track 1 x head instead of welding it up like I did. They run good too, but need shaft rockers. But he had these headz.. so we used them.steve cowan wrote: ↑Tue Apr 16, 2019 5:50 pm Randy,
can you give me your opinion on the brodix heads,we talked about the valve job previously but how did you find them to work "on",meaning CSA averages,seat concentric to the stems?,i know you did a valve job etc looking more for a comment saying they are poor-fair-good etc
i am curious on how the engine owners response was for the good gains,i understand the owner has spent the money but some people dont get the gains they think they should get.
a 383 sbc that makes great torque and 660-670hp
wish i had that lol
My opinion is, the choice of porters and what is done to the heads is more important than which head, as far as which 23* head.
I'll limit that to the usa made stuff at least.
If you want a 383 like this one, copy it. I'll tell you exactly what it has in it.
Just need to copy that port too.
that would be great,
we can talk later on when the time arises
steve c
"Pretty don't make power"
apples to oranges comparison in my opinion-
13.1 engine budget and time restraints and needed to reuse some parts.
700 hp 11.1 engine- 50 pages of information on this forum
steve c
Thanks...I was looking too far back.
Thats why I asked, taking some time to read through the old post I am not seeing anything that would make an 11.1 engine produce more power than a 13.1...steve cowan wrote: ↑Tue Apr 16, 2019 11:31 pmapples to oranges comparison in my opinion-
Fast burn heads better to start with? extra things done that are not obvious? combination of the head and intake on 1 vs the other mo happy together?
Here is the data. Sorry for the poor resolution. My crayon is dull.
“Pure logical thinking cannot yield us any knowledge of the empirical world; all knowledge of reality starts from experience and ends in it.”
Albert Einstein
Albert Einstein
