MOO to that!Warp Speed wrote: ↑Wed Apr 24, 2019 10:22 amBe it valve jobs, or this type of deal, it is amazing how combinations and usage that are so far apart, still respond the same. Engine combos change, but the physics involved don't.
before/after 383 dyno results
Re: before/after 383 dyno results
I wonder if having other belts on the front of the crank would calm some of that down a little ??
Like vacuum pump belt or alternator belt.
It could. A 7in damper would typically have the biggest effect.
Externally balanced?
Carburetor vibration isolation gasket I found is a 4277G Mr Gasket.....
When I had a Mercedes diesel they had a much better damping unit for the serpentine belt over the petrol versions. If there is a way to tension the belts with a gas/hydraulic piston to dissipate the torsional oscillations via heat rejection (ala a crank damper) that might be beneficial at the expense of bracketry and complexity.Warp Speed wrote: ↑Wed Apr 24, 2019 10:57 amIt could. A 7in damper would typically have the biggest effect.
No, internal balance.Warp Speed wrote: ↑Wed Apr 24, 2019 10:57 am It could. A 7in damper would typically have the biggest effect.
What about damper weight? Is their specific incidences that require running say a steel vs aluminum 7" or vice versa?Warp Speed wrote: ↑Wed Apr 24, 2019 10:57 amIt could. A 7in damper would typically have the biggest effect.
There is a 2017 thread on this -- viewtopic.php?t=50310
The Mopar unit was found on the 1.6 VW engines used in the Omni/Horizon (I had one). The EPA made them replace it because of failures in service with a solid aluminum unit.
Side draft Weber and Solex carbs had some similar ones from Renault in their Alpine/Gordini (also used in Matra Djet). Lessor quality units used O-rings and plastic carriers.
Good question.CGT wrote: ↑Wed Apr 24, 2019 11:24 amWhat about damper weight? Is their specific incidences that require running say a steel vs aluminum 7" or vice versa?Warp Speed wrote: ↑Wed Apr 24, 2019 10:57 amIt could. A 7in damper would typically have the biggest effect.
I have 3 inertia ring 7" ati on my 421, 3.875 stroke. Wonder if there is a better one ?
Ask them if they sell the elastomeric rings in different durometer ratings.
http://www.atiracing.com/instructions/918998.pdf
Better pic of the plug after the dyno session of the 383.
Got it started on Thursday on old plugs and made 3 breakin pulls, then Friday morning it got a look over and new plugs.
That plug has all the pulls made on Friday on it. (16 pulls)
I believe they do. They've told me to send one back for different durometer if we start operating the engine in a different rpm than it originally started out at.Kevin Johnson wrote: ↑Wed Apr 24, 2019 11:33 am Ask them if they sell the elastomeric rings in different durometer ratings.
randy331 wrote: ↑Wed Apr 24, 2019 12:08 pm Better pic of the plug after the dyno session of the 383.
Much better picture. How wide is the fuel ring?
My plug reading consists of looking for signs of detonation and contact with the piston.
I figure if it's going to the dyno I'll let it tell me fuel and timing requirments.
But, looking down in the plug I can't really see one. I haven't cut one apart yet.
