Let's discuss GM's new RUMORED Big Block reintroduction!
Re: Let's discuss GM's new RUMORED Big Block reintroduction!
All the way back in 99-2000? Seems to be when I remember it going from cheaper to more expensive in Pa. Trucks sitting being defaulted on, transport cost went crazy.
And then, if not mistaken, they had to add back a bit of 100 percent pure soy biodiesel to improve lubricity that the removed sulfur provided. I want to say a percent or two?68post wrote: ↑Wed Mar 06, 2019 9:50 pmThe claim is that all of the extra refining to remove the remaining sulphur (ULSD) is what drove the cost beyond gasoline.gnicholson wrote: ↑Wed Mar 06, 2019 5:33 pm not to get off topic but i would love someone to explain why diesel is .75 to a buck more a gallon than gasoline. is it really all the results of the commodities market? they would sure use a lot less fuel in this country if they would encourage diesel use
If they were I wasn't privy to know, I just added a dose of TW3 (?) Marine 2-cycle oil (approx 12 - 14 yrs ago).pdq67 wrote: ↑Thu Mar 07, 2019 10:39 pmAnd then, if not mistaken, they had to add back a bit of 100 percent pure soy biodiesel to improve lubricity that the removed sulfur provided. I want to say a percent or two?68post wrote: ↑Wed Mar 06, 2019 9:50 pmThe claim is that all of the extra refining to remove the remaining sulphur (ULSD) is what drove the cost beyond gasoline.gnicholson wrote: ↑Wed Mar 06, 2019 5:33 pm not to get off topic but i would love someone to explain why diesel is .75 to a buck more a gallon than gasoline. is it really all the results of the commodities market? they would sure use a lot less fuel in this country if they would encourage diesel use
When are they going to announce the new big block hemi for RAM trucks ?
Ed
How big do you think Dodge could go in bore and stroke in the old Viper engine design in a V-8 configuration. That seemed to be a decent OHV pushrod design?
Not sure if they sold that tooling and what not to Ilmor?
Have seen advertising from one source on the gen3 having 577-605 packages. Just under 10 liters. The 605 was huge bore and thin walls...
The new GM gasoline truck engine is 6.6L, based on LS architecture. Cast iron block, aluminum heads, forged steel crankshaft and 10.8:1 compression. This engine will be available with the GM-manufactured 6L90 six-speed automatic transmission. (available in the 2020 model year)
GM Duramax engine will be available with a ten-speed automatic transmission supplied by Allison.
Ford will have a new 7.3L gasoline engine, the largest available in this class of trucks (class 3 - 5)
Information from SAE International AUTOMOTIVE ENGINEERING Magazine, March 2019 issue.
Bill
SAE Member (30 years)
Bill, that was information released about 6 months ago to describe the larger 6.6LLT1-5 direct injected engine that GM has been offering in the 6.2L size in the trucks since 2014.
This current rumor about a larger big block has been said to be an engine larger than 8.0 liter and as a rumor who knows might just be a marketing ploy to counter Fords, new 7.3L release.
Bill, that was information released about 6 months ago to describe the larger 6.6 LT1- direct injected engine that GM has been offering in the 5.3L L83 and 6.2L L86 size in the trucks since 2014. It is just a stroked 6.2L L86 DI engine of the LT family.
I hope that maybe GM puts their genius caps on and does do something larger than 6.6L that will also be a simpler design than these new DI offerings.
We will all pretty much become Missourian's "Show Me" when it comes to automotive rumors. To many internet online publications today trying to build readership by throwing rumors against the wall like mud hoping some may stick. Some of these types could not tell a fuel injector from a spark plug!
What's that other great saying, "IF YOU CAN'T DAZZLE THEM WITH BRILLIANCE, THEN BAFFLE THEM WITH BULLSHIT"!!
Chrysler Viper V10 was(is?) based on the Chrysler LA engine. It was a Magnum 5.9L with 2 extra cylinders and a stroke of 3.88" instead of stock stock LA engine spec of 3.58" At this point, I'm not sure what the bore and stroke of the most recent Viper engine is, but I'm fairly certain it is still based on the basic design. Didn't ever hear about them re-engineering the engine in the middle of its lifespan or anything so, AFAIK, it's still LA-based.
So a bored and stroked 5.9L Magnum is what you're envisioning, basically. A 408 stroker. Current architecture is 4.055x3.96 or 8.4L. Do the math to figure cylinder volume and subtract 2 cylinders, you end up at 408/6.7L V8 from a 8.4L V10(.84Lx8 cyls=6.72L or about 409.2ci)
