Question for CAMSHAFT experts
swampbuggy
Post by swampbuggy »
OBJECTIVE is to calculate (figure) the MAXIMUM lobe lift for a given base-circle diameter on a given core diameter. Would this be the correct way to do this (or) did i miss something ? (core diameter) 55mm 2.167" minus 1.275" base-circle = .892" divided by 2 = .446" Max. lobe lift (lifter rise) and be able to get camshaft through cam bearings to install it. Mark H. :?: Thanks for any responses.
CamKing
Re: Question for CAMSHAFT experts
Post by CamKing »
Correct.
Journal diameter minus twice the lobe lift equals larges base circle diameter that will fit
or
Journal diameter minus base circle diameter equals twice the max lobe lift that will fit.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
swampbuggy
Thank you, Mike !!! :D Mark H.
