To save DV some time, this is his new BBC book: https://www.amazon.com/Chevy-Big-Blocks ... 1613251629
Cam Specs - and other
Re: Cam Specs - and other
Ah Yatahey, I went ahead and ordered it. Thanks Bill
-Carl
-Carl
Although this is on the pump now, endurance marine dealio should be ~1300hp on 91 octane but books are always good.
If you click on the pics they turn right side up.
-Carl
-Carl
Hi Bill,MadBill wrote: ↑Mon Feb 18, 2019 8:56 pmTo save DV some time, this is his new BBC book: https://www.amazon.com/Chevy-Big-Blocks ... 1613251629
That is the book I had, so I searched David's name...omg, he wrote a lot of books. I could not find another specific to the BBC, so if you know the name by all means please forward and thanks!
A tool that is in use, if dropped, will fall to a place directly proportional to the length of your arm plus 8 inches.
Hey Carl, you will enjoy the read. I probably reread it a couple of times for the details. A lot of good info. Kinda where I started other than buying the car and engine to rebuild.
Carl that is one sweet looking motor. Is it for a marine application? I would not mind putting a supercharger on, but hesitate cutting the hood and keeping my budget on track. Very nice and thanks for the share.
Yes, marine engine. Here's is a pic of a front feed hemi 2.9L kit. It's very low profile and you could do something like that for under the hood on a BBC, with efi it is shorter than a carb, also added some other pics. The name of the pics are what they are. I know off topic but thought I'd show off some projects.
Hemi 2.9L and BBC TBI Tunnel ram vvvvvvvvvvv 416 cu in LS with 4L vvvvvvvvvv
461 c in LS with 4.5 L vvvvvvvvvv
2.3L Ls truck kit vvvvvvvvvvvv
Dual 3.3L Quad rotor vvvvvvvvvvv Or you could go original old school and cut the hood.
-Carl
-Carl
Question about "132 for BBC"....
Does the 0.91 correction factor still apply? I assume this is for production BBC heads?
132 - ((ci/8/int valve dia) * 0.91) = LSA
Cam# BBC, HR75375-78360-112
241/251 @.050"
.375"/.360" Lobe Lift
112 LSA
241/251 @.050"
112 LSA
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
From the thread "128 cam spec revealed" (link above) the only change regardless of MFG was just the 132. Its a good read if you have not read through it. The 132 comes from the canted valve design over the "128" for SBC heads. Others have more information than I, so they pipe in, just an FYI it is only intended to spec the LSA.
Hi Mike,.
Thanks, the LSA seems high compared to DV math. But I am a novice so I appreciate the advice/spec.
So a question that I would really like to learn more about is the cam angle setting. Straight up? Advance? Retard? Was hoping to read the post on that. I searched but could not it elsewhere. Any thoughts?
Thanks,
Paul
Carl, those are some nice looking engines, really appreciate the nice work. It raised a question for me. Does whipple make a intake set-up sans inter-cooler for a BBC? I looked, never found one. I really like the look of the LS design and would like that on a BBC with a port injection intake.In-Tech wrote: ↑Tue Feb 19, 2019 12:03 am Yes, marine engine. Here's is a pic of a front feed hemi 2.9L kit. It's very low profile and you could do something like that for under the hood on a BBC, with efi it is shorter than a carb, also added some other pics. The name of the pics are what they are. I know off topic but thought I'd show off some projects.
The old school look is so nice. I just don't think I'd like looking at it while driving measured it up and its going to pop out pretty high.
Yeah, Whip has a dual injector(16) intercooled manifold with different variety height intercooler cores. I thought I had a pic of one on this puter but guess not. I'll post one next week with dimensions. Thanks for the compliments. I was poking a little fun about buying the book as if I don't have any experience with BBC. If I only learn one thing, any book is well worth the money plus it's nice to see others views on things.
It's pretty amazing how well the TBI type Whip blower manifold works without individual cylinder trim. You can see by the pics that there is a wide band on each port. The standard firing order cam has really poor cylinder distribution at light throttle(pre boost), as much as 4 AFR between cylinders, the LS firing order gets it ~1.5 AFR between cylinders and again, either firing order pretty much straightens out the AFR between cylinders after 1 psi of boost even though it screws to the front. The intercooler core only being a half inch off the floor aids in all of that.
-Carl
-Carl
I would install it on a 108 Intake Centerline.Mechcanic wrote: ↑Wed Feb 20, 2019 12:33 amHi Mike,.
Thanks,
Paul
I widened the LSA to extend the top-end power, and increase vacuum. It will cost a little peak torque, but with a 4.25" stroke, torque won't be an issue.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
- Stan Weiss
Not sure where this came from. 132 was only for BBC. 128 was only for SBC and I believe 127 for SBF. The way I read it no other makes were implied.Mechcanic wrote: ↑Wed Feb 20, 2019 12:28 amFrom the thread "128 cam spec revealed" (link above) the only change regardless of MFG was just the 132. Its a good read if you have not read through it. The 132 comes from the canted valve design over the "128" for SBC heads. Others have more information than I, so they pipe in, just an FYI it is only intended to spec the LSA.
Stan
