600+HP with a FT cam, 355 cubes & OEM iron heads
Re: 600+HP with a FT cam, 355 cubes & OEM iron heads
Valves are just 11/32 steel ferria.
Manley TS retainers, pac springs - 160lb on the seat, edm lifters, around 500lb over the nose.
Regular cam, just broken in carefully with plenty of zinc & the inner springs removed.
No bsfc's, only really hook up the fuel flow for r&d, when you have no intention of changing anything internal in the engine bsfc is kinda moot.
