Hello,
I have a question about a set of GM LS heads (2008 L92 / 6.2 truck motor) on the valve stem to guide clearance. The guides are magnetic...not sure if they are powdered metal or not. The valves are new.
I measured the ID of the guides with a snap gauge. Then I rechecked the measurements by setting the snap gauge just a touch above the measured ID and tried to insert the snap gauge. This verified the measurements. I measured some of the valve stems with a micrometer. All those measured were very close to 0.3130".
The tightest valve stem to guide clearance is 0.0020".
The loosest valve stem to guide clearance is 0.0035".
The average valve stem to guide clearance is 0.0026".
There is one guide that is a good bit looser than all the rest (that's the 0.0035" one).
The factory service manual says clearances for both intake and exhaust are:
Production: 0.0010" to 0.0026"
Service: 0.0037"
Clearances look to be on the loose side to me. Would you bother with replacing and resizing these guides?
I could not find replacement powdered metal guides for these heads. Sealed Power has a VG-1434 valve guide for these heads but the material is not specified. According to the ID of this replacement guide, clearance would be at 0.0024", which isn't all that great.
Sealed Power VG-1434:
https://fme-cat.com/overlays/part-detai ... 01500&vin=
Thank you for any help,
Paul Lohr
Valve guides on GM LS heads
- New Member
Re: Valve guides on GM LS heads
Jmo replace the loose guide then use the the heads as they are.
Rember when u replace the guide it may tighten up after installation and need to be resized.
John
John
Ferrera also lists a couple of different guides, none being the one you listed. I suspect these are manganese bronze.
VG1066 for intake guide
VG1067 for exhaust
.501" ID & 2.000 length. Uses valve guide seal VS1021
VG1067 for exhaust
- New Member
midnightbluS10, thank you. I will check into the Ferrea valve guides in terms of how durable they are compared to powdered metal.
John, thank you. Replacing the guide that is loosest might be the most reasonable idea. Good point about the new guide tightening after installation. I wonder how much a powdered metal guide's ID would tighten in an aluminum head?
If anyone knows where I can find powdered metal guides, or has other ideas, please feel free to share.
- New Member
I know Texas Speed and Performance has PM guides as an option for guys running stock type rockers on their heads, you may try to buy one from them, i think PM guides also run a slightly tighter clearance iirc?
Just to ask since this post came up. Guides wear like an hour glass, more at the ends than in the middle. Instead of using a snap gauge, I hold the valves off the seat approx.,lift of cam,I use a piece off vacuum hoseto hold them up, and then rock them with a dial indicator and divide the movement by 2 to obtain the guide clearance. I think several manufactures used to promote this method. Using a snap gauge you have to take multiple measurements and average the results. Does anybody use this method, or am I all wet?
Honestly, have someone with a sunnen p series valve guide measuring gauge double check before you spend money on the guides
Aren't those clearances sort of large for a "modern" engine? What is the seat run out?
