PSI valve springs
winterhoff
PSI valve springs
Post by winterhoff » Thu Dec 06, 2018 6:40 pm
Anybody have a good source for PSI springs JHE- 10A and JHE-002 retainers
Thanks Ron
Newold1
Re: PSI valve springs
Post by Newold1 » Thu Dec 06, 2018 8:22 pm
Summit actually stocks and sells some of the PSI spring sets.
As for your area, give PSI a call and they will direct you to a few sellers in your area.
Abbottracingheads
Post by Abbottracingheads » Fri Dec 07, 2018 11:05 am
CV Products or Motorsports Unlimited.
ou812
Post by ou812 » Fri Dec 07, 2018 1:02 pm
Isky sells them, and I believe * sells them also.
Brian Hafliger
IMM Engine & Dyno
http://www.immengines.com
http://www.neilhepburn.com
Coloradoracer
Post by Coloradoracer » Sun Dec 09, 2018 9:22 am
Call PSI directly. They are great to deal with and will put you in contact with a retailer they recommend. I did and they even gave me a discounted price. Nice folks.
Mark Goulette
Authorized Amsoil Retailer
cpmotors
Post by cpmotors » Sun Dec 09, 2018 4:46 pm
X2 On Ken @ MSU. 216-390-4561
Pete Graves
CPMotorworks,Inc.
Custom Engine Machining
Cylinder Head Fixture for Vertical / Surfacing Mills
Charliesauto
Post by Charliesauto » Sun Dec 09, 2018 5:19 pm
Thanks Ron
Those JHE PN's are only available from Hornick, the springs are exclusive designs made for JHE by PSI.
I believe you will have to buy the springs from Joe. May be able to source a compatible retainer through DW or Xceldyne.
If you go to his website, find the valve spring spec page and scroll to the bottom for the JHE #'s.
JHE contact (704)664-7322 jheinc.com
LSP
Post by LSP » Tue Dec 11, 2018 9:50 am
Thanks Ron
Correct, ask for Rick @ JHE Inc.
Wish I had time to be a Guru
