roller crankshaft thrust washer failure
englertracing
Post by englertracing » Wed Dec 05, 2018 7:26 pm
4 stroke.
was not ran out of oil.
oil is fed through the end of the crankshaft.
any ideas?
hoodeng
Re: roller crankshaft thrust washer failure
Post by hoodeng » Wed Dec 05, 2018 7:30 pm
What does the thrust face of the rod and wheel look like on the side of the failure and off side? is the i/d large enough for it to float out of the groove?
Cheers.
naukkis79
Post by naukkis79 » Wed Dec 05, 2018 8:29 pm
Either bend rod or crank.
Kevin Johnson
Post by Kevin Johnson » Wed Dec 05, 2018 8:32 pm
The patina from oil exposure is different on the rod beam versus the crankshaft counterweights as well as the case halves. How many times has it been rebuilt and was this an original bearing?
englertracing
Post by englertracing » Wed Dec 05, 2018 9:35 pm
Kevin its been apart once to fix an issue with the transmission. I replaced only transmission components and the piston and piston pin.
Honda m/c cranks always have a weird copper color on the throws, I suspect that they are cast steel and that they are carburized. It actually looks just the way it did 5 years and about 200 hours ago, at which time it probably had 100 hours. General consensus on the internet is that the crankshaft should be replaced or rebuilt at 250 hours. Would have been a fantastic time to replace mine....
I looked at it a little bit more.
I checked what the side clearance would be with the washer in place, around 0.020"
then I noticed it.
The bearing cage slid over, If you look closely, the cage is in multiple pieces.
I believe the cage broke and abraded the washer.
Interestingly there is no detectable radial play, and it still feels extremely smooth.
Kevin Johnson
Post by Kevin Johnson » Wed Dec 05, 2018 9:42 pm
That is impressive and valuable feedback from other owners. The only comparable thing that pops into my head is when I owned a Mercedes diesel and people warned about the bearings in the vacuum pump typically failing at a known mileage range.
