292 flow #s
Re: 292 flow #s
Would be nice if there was a way to fill the water jacket on those above the ports. Really thin up there near the rocker studs and valve spring pockets.
Re: 292 flow #s
Those ports must be cut to the max I believe. I have had 2 sets of 292s over the years. On both of them the rocker stud boss was a blind holes That does not break into the intake ports. The top of the port is a lot thicker . Dancgarb wrote:Would be nice if there was a way to fill the water jacket on those above the ports. Really thin up there near the rocker studs and valve spring pockets.
Re: 292 flow #s
I have a set also, yes mine aren't broke into the stud hole either. I was just saying from a porting standpoint and strength standpoint if they were solid there the head would have way more potential. I have heard of those heads cracking into the water jacket from the spring pockets when they are cut deeper and larger for roller cams. If that area didn't have water there that issue wouldn't be a problem.
Re: 292 flow #s
It does look like there is only about .030" of material there after porting...that's cutting it pretty close. Probably wouldn't want to forget to turn the fan on with those heads...or you will have a sprinkler for sure.
Re: 292 flow #s
My buddy has a set of 292's with about 4-6lbs of brazing material added to the casting....they were off a NHRA record holder that ran out of his shop in the late 70's.....he has an old electric oven with multiple heating elements he used to use for bringing the castings up to temp and taking them down to room temp as he was adding material. I have a nicely done set of 292's that basically copy the Chevy Power guidelines and probably flow around 250CFM of air @0.600" with 205/160 valves. The head porters had a rough time with the replacement Bow tie castings when they tried their "Turbo techniques" in porting them because of the major changes to the short side hump in the Bow ties....their methods didn't work too well with those Bow tie castings.
Re: 292 flow #s
TIA
Dave
Re: 292 flow #s
Doesnt Smokeys book show a cross section on how to port the 292sdave brode wrote:Please tell me more about the book.ZEOHSIX wrote:
TIA
Dave
Re: 292 flow #s
It's the Chevy Power guide book sold over the counter in the late 70's early 80's if I can find my copy....Ill post some pages out of the manual. There were blueprint drawings in it of 292 porting cross sections commissioned by Chevy.dave brode wrote:Please tell me more about the book.ZEOHSIX wrote:
TIA
Dave
I just did a quick search on EBay.....go to auto literature and manuals there are a few......my version was the 3rd edition circa 1978 year book....the early 80's edition dropped the 292 porting for Bowtie castings.....Look for the one with the IMSA Monza on it and Formula 5000 car.
Re: 292 flow #s
With a 2.08" diameter, 5/16" stemm valve, 50 degree seat ... probably.cgarb wrote:Can a set of 292's get in the 280's without tubing the bolt holes and welding on the pushrod pinch area?
The Diamond / Elkins "Winston Cup" heads I referred to ten years ago on this thread were on my very first 366 Engine Masters entry some 15 years ago.
Re: 292 flow #s
double post ... impatience
Re: 292 flow #s
Have a set on a meticulously well-matched 355 build in a '65 Chevelle SS 4-speed. ('66 has is a BBC/AGE)
Had them done by Gene Fulton, around 5 years ago. He got all nostalgic about doing another set & seemed "happy" to re-visit his days churning them out for many of the record-holding M/P SBC cars of the day.
The winning M/P race team from those days I remember the most are the Marshall Tucker Band 66-67 Novas.
Gene's shop built every aspect of those cars and fortunately the 2 Tucker boys were also gifted drivers.
Re: 292 flow #s
here you go 292 head porting. I also have the CI bow tie specs
Re: 292 flow #s
butch and jim did the heads for my NASCAR cup engines. #82 carWalter R. Malik wrote:With a 2.08" diameter, 5/16" stemm valve, 50 degree seat ... probably.cgarb wrote:Can a set of 292's get in the 280's without tubing the bolt holes and welding on the pushrod pinch area?
