New Mellings Ls oil pump. Looks to be great for Rpm 15% less oil volume.
Rowdy Yates
Post by Rowdy Yates » Sun Dec 02, 2018 8:34 am
https://www.melling.com/5-25-18-new-...y-main-oiling/
Will call tomorrow to find out if it's useable on the normal Ls platform. Kurt Urban did say spinning the rotor less would help with windage if I'm not mistaken. Great for higher Rpm.
Coloradoracer
Re: New Mellings Ls oil pump. Looks to be great for Rpm 15% less oil volume.
Post by Coloradoracer » Sun Dec 02, 2018 9:24 am
It's "Melling", not "Mellings".......Just an fyi
Mark Goulette
Authorized Amsoil Retailer
steve316
Post by steve316 » Sun Dec 02, 2018 9:47 am
Spelling not all it cracked up to be.
Coloradoracer
Post by Coloradoracer » Sun Dec 02, 2018 10:07 am
If it wasn't for spellcheck I'd be in trouble.....
Mark Goulette
Newold1
Post by Newold1 » Sun Dec 02, 2018 10:37 am
Whaat thea hecck is spelcheeck? :lol:
Caprimaniac
Post by Caprimaniac » Sun Dec 02, 2018 1:57 pm
Mellings or Lemmings?
BTW- less volume- will still be good with 0-30w oil?
I’m poundering- stock or. More volume with thin oil, thin rings and 8500 rpm.
Rowdy Yates
Post by Rowdy Yates » Sun Dec 02, 2018 3:11 pm
Higher Rpm doesn't necessarily mean you need a high volume oil pump. Typical less would be better on a Ls slower gear ratio = less windage @ higher Rpm or less volume. High pressure standard volume is great yet with less volume would be better. About the oil I'd call Melling.
Keith Morganstein
Re: Melling’s new Ls oil pump. Looks to be great for Rpm 15% less oil volume.
Post by Keith Morganstein » Sun Dec 02, 2018 9:00 pm
How about “Melling’s new”
Olds455
Post by Olds455 » Mon Dec 03, 2018 3:01 am
That would necessitate a rewrite of the heading of this thread. "New Mellings LS.." can't just become Melling's new LS...without some sort of editing. Lol
Post by gmrocket » Mon Dec 03, 2018 4:01 am
Link isn't working.. is there a part #?
Walter R. Malik
Post by Walter R. Malik » Mon Dec 03, 2018 11:14 am
It has less volume but, it also LEAKS a lot less; not as much wasted volume.
Rowdy Yates
Post by Rowdy Yates » Mon Dec 03, 2018 1:01 pm
Can be used with standard Ls blocks..... Just called it in, stated production starts some time in the wk or so.
BTW these are cheap was told about them about 3wks ago from a friend @ Comp cams.
https://www.lsxmag.com/features/sema-co ... s-engines/
