Header Theory by Vince Roman from Burns @ PRI
digger
Re: Header Theory by Vince Roman from Burns @ PRI
Post by digger » Sun Dec 09, 2018 11:01 pm
What about IR intake with zoomies ?
GARY C
Post by GARY C » Sun Dec 09, 2018 11:42 pm
I thought it was determined years ago the need to time each primary tubes individual pulse in the collector ruled out equal length tubes?
mk e
Post by mk e » Mon Dec 10, 2018 7:54 am
David Vizard wrote:
Sun Dec 09, 2018 10:47 pm
swampbuggy wrote:
Sun Dec 09, 2018 8:45 pm
Gotcha Firedome8, If a V-8 engine was as close to PERFECT in design as mechanically possible i think we can agree that all parts and dimensions for each cylinder ( intake runner, intake port, valve size, port flow/shape, piston crown/shape, cc's of combustion chamber/shape, should be as close to identical to each other as possible. If this was the case, which it usually is NOT, each header primary pipe would want to be equal length one to another. I guess it is possible to change the primary length on a certain cylinder in an attempt to correct an imbalance on the intake side of the cyl. head :?: :?: Mark H.
It still would not want even close to identical lengths!!!!!!
DV
This has gone in an interesting direction.
My understanding is that many development efforts use single cylinder setups for their testing, assuming the results for any number of added cylinders would be identical (other than friction) and testing 1 cylinder dramatically reduces time and cost. Every simulation software I've ever seen makes a similar assumption.
I'm completely on board with Calvin's statements that better flow is normally more important that exactly matched tube lengths....and that assertion can easily be duplicated in simulations by plugging in head+header flow data. Makes sense.
The idea that matched cylinders DO NOT match I think will need some splainin' ??????
Mark
Mechanical Engineer
digger
Post by digger » Mon Dec 10, 2018 8:30 am
If the cylinders are connected downstream in the exhaust then each cylinder affects another and probably in different ways so the engine is not simply 8 of the same single cylinder engines
RevTheory
Post by RevTheory » Mon Dec 10, 2018 8:35 am
I would assume that uneven pulses bank-to-bank play a big roll here.
mk e
Post by mk e » Mon Dec 10, 2018 8:46 am
The simulator I have assumes no......the important word being assumes. They say that's based on test data and as I said I know a lot of places like, f1 teams, do a lot of development on 1 cylinder setups.
As someone else said, an 8 cylinder with ITBs and zombies is effectively 8 single cylinder engines......as I'm really struggling with what seems to be an assertion that even balanced/matched it's not balanced/matched and requires exhaust changes.
Mark
Mechanical Engineer
digger
Post by digger » Mon Dec 10, 2018 8:57 am
Some things probably work on a single cylinder from a correlation perspective but not all.
I'm pretty sure engmod you get different exhaust traces in each cylinder. It's been a while since I've looked at that
mk e
Post by mk e » Mon Dec 10, 2018 9:10 am
The stuff I've messed with over the years is even spaced or separate or both so I have basically no experience with uneven pulses. Once you connect the cylinders, particularly on an uneven setup as Rev suggested I'm sure something happens......which is why I'm interested in hearing what, and even more interested in seeing the data that supports the explanation :)
Mark
Mechanical Engineer
Newold1
Post by Newold1 » Mon Dec 10, 2018 10:31 am
Asked earlier her, but did Vince at Burns discuss or talk about in his seminar the question of equal length primaries and equal length 4-1 headers?? Users wan't to know!
GARY C
Post by GARY C » Mon Dec 10, 2018 11:19 am
If not then I doubt merge collectors and wings in the collectors or collector size would be of any benefit but most perfect header designs go out the window when you factor in that they have to fit in a chassis.
David Redszus
Post by David Redszus » Mon Dec 10, 2018 12:24 pm
Quite right.
Long ago I was taught that equal length properly refers to equal FLOW length, not MEASURED length.
Reason being that pressure waves travel along the shortest path, while air particles prefer to travel
along the straightest path.
Consequently, each pipe bend or diameter change will affect pressure waves and wall friction will affect
mass flow. Additionally, exhaust gas temperature will affect sonic velocity and air density.
Pipe pressure sensing at each exhaust port will quickly reveal things we would rather not see.
But the issues are still with us, like it or not.
vannik
Post by vannik » Mon Dec 10, 2018 12:30 pm
I'm pretty sure engmod4t you get different exhaust traces in each cylinder. It's been a while since I've looked at that
Correct. Nowadays a very small number of sims do not do each cylinder individually. It just makes too many assumptions.
ClassAct
Post by ClassAct » Mon Dec 10, 2018 12:46 pm
Quite right.
How do you determine the flow? On a flow bench? If so, what test pressure? If not a flow bench, what method of testing is used.
Since I started reading hear (before I joined) I did some reading at Elstons web site. I realize optimally you want the minimum of bends,and of those bends you want the radius as large as possible. For me, the rub starts when you are stuck dealing with stock bodied cars. Unless the primary tube is 1 inch, it's near impossible to get the tube straight for any length of time. Same goes for keeping the bends from being sharp. My question is in those cases, is the smaller tube still a better alternative? And then the length question comes up. Do you keep a bend nice and smooooooth and then add 3-4 inches to that pipe, or do you just live with the tight radius and make them all the same?
mk e
Post by mk e » Mon Dec 10, 2018 1:35 pm
Are you talking about all setups or just uneven setups?
If all setups what differences are there that you're tracking?
Mark
Mechanical Engineer
Jim2527
Post by Jim2527 » Mon Dec 10, 2018 2:29 pm
This is a pic I lifted from another site. Its a 180 degree C6 Corvette piece. IIRC the owner/welder strived for equal length tubes. Seems like the owner/welder should've sacrificed equal length for smoother bends?
