Would you build a stock block 427" SBC today?
We are trying to chase away a customer who wants a low-buck 427" SBC, using a 400" block. This wouldn't be a max-effort build. but since the affordable Chicom stroker kits are all over the internet, he thinks it's great for bragging rights over the 406"s.
Aside from having to use a small-base-circle cam, what other reasons would you not go there these days?
- Dave Koehler
Re: Would you build a stock block 427" SBC today?
low buck, budget, bragging rights, 400 oem block
Just say No?
Edit: IF he wants to be the engine assembler/builder and you handle the machinework that might be one way to keep it at arms length.
Other than that too many red flags.
Just say No?
Go for it....I'm way past teaching customers lessons.
I make it crystal clear what can happen, they sign the work order which explains everything in detail.
It's no skin off my azz...or reputation.
Some guys just don't have the money , time or patience to wait and do things right.. they seem to have just as much fun blowing shyt up as I do not doing that
I have a guy right now begging me to build a big inch small block Olds..in the 480 to 500 range.he has most of the parts and it can be done
If he's talking bragging rights over a 406 I'd say no. I've done a lot of 406s in the 650-750 hp range. Stock blocks will crack with them so don't see it getting better with more cubes.
Monty Frerichs
B&M Machine
B&M Machine
This is the inexplicable; no one can see any difference looking at it. He could be running a 350" with a Big Mutha Thumpr and lots of exterior bling and save himself a lot of money and potential grief.
- af2
Cash and no receipt is your friend on this one!!
GURU is only a name.
An LSX or Coyote are vastly superior engines, why bother with antiques?PackardV8 wrote: ↑Mon Nov 19, 2018 3:47 pm We are trying to chase away a customer who wants a low-buck 427" SBC, using a 400" block. This wouldn't be a max-effort build. but since the affordable Chicom stroker kits are all over the internet, he thinks it's great for bragging rights over the 406"s.
I don't think I even saw a gen 1 SBC at SEMA this year.
Last V8 I was involved with was a 383 Chrysler with a 4.25" Chinese crank & rods, about ten years ago.
IIRC, the machine work (bore, hone w/ plates, line bore, decking, oil system mods, was a pretty good chunk of change. Like it flattened a thousand dollar bill.
If I could've got a beefier aftermarket block from Summit/Jegs/Amazon Prime at <$2k, I would have jumped at it - the thought of possibly breaking a lump of iron that's just had $$$ spent on massaging it never has sat well with me.
seduce the attractive... charm the rest
My thoughts are somewhat crazy. I don't care what engine type. As long as I can get the head & intake package wanted it doesn't matter. Some things are working Backwards and placing a 4 inch crank in a stock 400 block is one. Stick to a 406 as listed by Dave Koehler, SupStk and Steve good forged bottom end and decent set of heads. The machine work with Balancing along with stuffing a fat chicken inside a duck.. Crank inside the block your asking for trouble. Rpm is not your friend with a stock 400 and four inch crank. A 406 that rev's should make the HP wanted with good heads Rpm with compression. And best of all its a happier engine. Which means longevity. I'd look for a raised runner head for a 406 and not stroker crank.
A lot of guys like to have a certain engine just for bragging rights as mentioned. Many never use all the power anyways if it's a street engine...On one hand, the customer wants you do do work you personally think is dumb...and perhaps you don't want the bad press if it blows up..On the other hand,just do what the customer wants, it's his money...Yes?
I have built a two of these using 3.940 stroke and a 4.155 bore by using a small journal crank and com star rods I was able to run a standard base circle cam; no grinding for clearance. Going with a Dart SHP block and shelf pistons for 421 with 1.062 comp. height. You don't need to deck the block, plus .004 deck height; that save you some time & money. What I am trying to say is for few dollars more you will have piece built right; give your customer the choice. Then you can rest easy.
No matter how you do the math - old stock block SBC + 427 cubic inches = 0 !!
I will go with the majority, 400 stock block at the least will crack and blow head gaskets, and the worst big boom, not a question of if, just when. I learned my lesson many years ago with 440 mopar blocks, the aftermarket block was the most cost effective purchase I have ever made for my race car.
