Holley 300-261
Holley 300-261
Anyone here have any experience with this manifold -------Considering for a 2 bbl 500cfm drag motor 360ci 9.8-1 262/266 .550lift ported 441 heads currently using Victor 4x4--RPM Range 5000-7300---Dyno 452@6200rpm Have also considered VicJr Thanks for any feedback
Re: Holley 300-261
What is the port opening size as ported on your 441 heads?
Do you know the flow numbers for your valve size as ported?
Re: Holley 300-261
Use the Holley 300-110 intake with a taller height and better transition from a 2 barrel adapter.
You will be glad you did!
Re: Holley 300-261
I ran that Victor 4+4 years ago and almost any manifold is better that that. For instance, I borrowed a Vic Jr and it was .15 quicker than the 4+4, had to return the Vic Jr and the car slowed down .15
Re: Holley 300-261
On the 4412 carbed circle track engine we dyno tested it ... the Professional Products #52032 was slightly more powerful everywhere at wide open throttle. Part throttle transition and driving quality were not tested and that sometimes means more than a little bit of power.
Re: Holley 300-261
I saw something on FB bout this intake the other day and almost made my own post, thought it said it was new. I'd like to see a test vs a air gap style high rise dual plane with a more street/strip combo, hardcore race combos will still favor the larger single planes I bet.
https://www.holley.com/products/intakes ... ts/300-261 300-260 is the multi port version
