How to figure cam overlap?
econo racer
Post by econo racer » Tue Nov 13, 2018 2:53 pm
When reading a cam card how do I figure this out? Thanks!
F-BIRD'88
Re: How to figure cam overlap?
Post by F-BIRD'88 » Tue Nov 13, 2018 3:24 pm
Add up in,ake and ex duration and divide by 2.
Divide that result by 2 again and subtract lsa.
Multiply that x2. = overlap.
BradH
Post by BradH » Tue Nov 13, 2018 3:28 pm
# of degrees the intake opens before TDC + # of degrees the exhaust closes after TDC
Example:
Intake opens 30* before TDC
Exhaust closes 30* after TDC
Overlap = 60*
Keep in mind that it's going to depend on where on the lobe you're measuring the duration, too. The overlap measured at effective seat duration is going to look much larger than if measured at .050" lobe lift.
I hope this helps. - Brad
Newold1
Post by Newold1 » Tue Nov 13, 2018 5:15 pm
F-BIRD88 :
I am having issues trying to make your formula work?
A cam has 232 @ 50 intake duration and a 242 @ 50 exhaust duration with a 112 LSA
Using your formula as given - 232 + 242 divide by 2= 237 divide by 2 = 118.5 - 112 = 6.5 x 2 = 13 degrees overlap ?? seems a bit small ??
PRH
Post by PRH » Tue Nov 13, 2018 5:35 pm
Overlap is “usually” associated with the advertised duration.
In the above example, 13 is correct for overlap @.050.
I do it similarly to the formula you used if I don’t know(or want to calculate) the open and close points.
Duration for intake/exhaust added together, divide by two, minus two times the lsa angle.
232 + 242 = 474
474/2= 237
237 - (112 x 2) = 13
Newold1
Post by Newold1 » Tue Nov 13, 2018 7:32 pm
Got it, forgot to think advertised versus @50.
07GTS
Post by 07GTS » Wed Nov 14, 2018 4:07 am
can be a noticeable difference mine was about 5 deg at .050 but at .006 its 57 deg overlap
CGT
Post by CGT » Wed Nov 14, 2018 8:58 am
:lol:
"If you pick up a starving dog and make him prosperous, He will not bite you. This is the principal difference between a dog and a man"
pastry_chef
Post by pastry_chef » Wed Nov 14, 2018 10:35 am
Some time back I composed an excel, it backwards calculates from overlap and LSA to int and exh duration.
http://speedtalk.com/forum/viewtopic.php?f=1&t=54556
Mike R
