2009 2010 F1 non DI Fuel Systems
grandsport51
Post by grandsport51 » Sat Nov 10, 2018 9:14 am
Just look at this explanation of last MPFI Systems
On last gen NA F1 engines
http://www.racecar-engineering.com/arti ... l-systems/
Dave B.
LIGHT 'EM UP
mk e
Re: 2009 2010 F1 non DI Fuel Systems
Post by mk e » Mon Nov 12, 2018 7:45 am
I found this interesting. Very high pressure so probably very fine most and 40% duty cycle so they are only spraying into the moving air stream.
Injection pressure is limited to a maximum of 100 bar......
18,000rpm – before the limiter kicks in – the fuel injector is fired once every 6.6ms for a duration of 2.7ms at full throttle.
Mark
Mechanical Engineer
hoffman900
Post by hoffman900 » Mon Nov 12, 2018 7:57 am
The Honda papers show when they start/end injecting. Of course that was ten years ago...
-Bob
peejay
Post by peejay » Mon Nov 12, 2018 7:12 pm
I would think, depending on how the injectors are placed and oriented, injecting when the air is moving would be the furthest from optimal, from an airflow standpoint. The injector stream can act as an air door.
Only dyno testing can tell you for sure.
hoffman900
Post by hoffman900 » Mon Nov 12, 2018 7:26 pm
Development of High-Pressure Fuel Supply System for Formula One Engine : www.f1-forecast.com/pdf/F1-Files/Honda/F1-SP2_15e.pdf
-Bob
mk e
Post by mk e » Tue Nov 13, 2018 7:55 am
Spraying into the moving stream should produce the maximum air cooling effect. Any fuel that lands on the runner or port walls will cool the runner/port instead of the air so the effect is mostly wasted and you risk drops falling in which won't burn well.
Mark
Mechanical Engineer
hoffman900
Post by hoffman900 » Tue Nov 13, 2018 9:55 am
Check the link I posted and they show exactly when there injecting in the cycle. It’s not just during valve open.
-Bob
mk e
Post by mk e » Tue Nov 13, 2018 10:05 am
But its mostly just during ivo and they say is for the purpose of air cooling. They appear to have been flow rate limited and kept ramping up pressure to increase flow.
Mark
Mechanical Engineer
mk e
Post by mk e » Tue Nov 13, 2018 10:12 am
I'll add that more interesting to me is that pretty much anyone can now have this same tuning control. Big well matched and characterized injectors are readily available as are ecus that are fast enough to handle this.
Mark
Mechanical Engineer
hoffman900
Post by hoffman900 » Tue Nov 13, 2018 10:28 am
They reported a decrease in droplet size with higher pressures, that’s not a flow issue. They were also able to measure the cooling effects by the change in pulse timing due to density changes.
-Bob
mk e
Post by mk e » Tue Nov 13, 2018 10:36 am
They didn't reduce the injector size to get constant pulse time with varying pressure. Yes the droplets were smaller but the injection pulse was also shorter and more complete at ivc. They appeared to specifically avoid spraying near ivo.
The only conclusion possible is that higher pressure helped.....
Mark
Mechanical Engineer
Ken_Parkman
Post by Ken_Parkman » Tue Nov 13, 2018 12:27 pm
Fuel injectors without air are very poor for atomization and providing a burnable mixture; at a clear disadvantage to a carb which has emulsification. One of the ways to improve the inherent poor fuel spray quality of a pressure atomizing injector is jack the pressure to the moon. That and the nozzle location for heat of vaporization is making up for the inherent fuel injection disadvantage for power.
hoffman900
Post by hoffman900 » Tue Nov 13, 2018 7:07 pm
Honda reported they were able to reduce fuel droplet size to <20μm* by increasing pressure, which increased power and reduced adherence to port walls. In Phase 5 development (2009), they were able to increase the injector plate pressure from 4.7 to 8.9 MPA (despite a rule imposed ceiling of 10 MPA for the feed), and achieved an average a droplet size of 17μm.
<20μm = <0.000787402". For reference a red blood cell is ~5-8μm, so this is very tiny.
This is also interesting...
"The relationship between penetration and the phase of intake air pulsation was also sutdied. As Fig. 8 shows, there is a peak in the intake air phase delay, indicating the existence of an optimum penetration for the achievement of increased intake air cooling efficiency. If the level of penetration is low, the spray will approach the center of the port due to the effect of the intake air. If the fuel is carried too high, the amount of fuel adhering to the walls of the port will increase".
So in short, Formula One doesn't need textured ports because the injectors are atomizing the fuel so well. No carburetor is coming close to that. They're actually using the phase delay of the intake pulse to measure the atomization and charge cooling effect and were able to tune it. Not bad for being over a decade ago ;)
I would love to know where they are at a decade later.
-Bob
peejay
Post by peejay » Tue Nov 13, 2018 8:04 pm
At IVO the air is probably not moving fast yet (you think?) and weighing the air down with fuel would make it more difficult to get the air moving. By spraying toward the end of the event, they would be spraying into fast moving air and the added mass could be helping things along, inertia-wise, past BDC.
I also wonder if there is not a benefit for having the fuel in the "last air" into the cylinder. The last air in to the chamber may end up being closest to the plug. Given fuel limitations, they're under pressure to maximize fuel efficiency. The only documentation regarding THAT that I have ever read was that Honda had been running in the region of 1.1 lambda at max power... My assumption is that is an "overall" lambda figure and the mixture was considerably richer closer to the spark plug.
hoffman900
Post by hoffman900 » Tue Nov 13, 2018 8:15 pm
I thought it was interesting that they were still spraying AFTER IVC.
-Bob
