Real Budget Vortec Engine build
GARY C
Re: Real Budget Vortec Engine build
Post by GARY C » Sun Mar 10, 2019 1:41 pm
CGT wrote:
Sun Mar 10, 2019 11:21 am
steve cowan wrote:
Sun Mar 10, 2019 1:07 am
C H A D,
did i see 499 hp @ 6000 on slo svt spreadsheet?
thanks for the colour code on spreadsheet
real nice job C H A D thats a nice street engine with a bit of poke,would you share your thoughts on the 1.6 rocker on the exhaust,carry past peak at higher rpm??
thanks for going to the effort of sharing part # of springs etc,save a guy a lot of heart ache concerning retainer to guide clearance etc,is the cam a shelf or a custom grind??
i really enjoy the small cylinder head/camshaft combinations,so much to be learnt :D
I havent viewed the spreadsheet yet but if you look at the last 2 or 3 pulls where its showing 480ish pounds and look at coolant temp on those you will see we were playing with cold water in the engine. I kind of wanted to see the effect of it and he wanted more facebook power so... :roll:
I believe the best pull with normal water temps was 465ftlbs and 488 or 484hp. Some changes from the beginning of the thread were made. A used set of pac 1518 springs were used on it. Joe Creason donated those. 1.94 intake valve 52 degree seat 1.5 ex 50 degree. 238 248 .525 .500 104 cam was used....Comp Marine lobes.
It runs good. Brenden is ecstatic about it....."Dale" seems like a nice tight little motor and as always plenty of things i would do differently now...
Good build, I bet he can't wait to get it in the car.
CGT
Post by CGT » Sun Mar 10, 2019 3:06 pm
"If you pick up a starving dog and make him prosperous, He will not bite you. This is the principal difference between a dog and a man"
CGT
Post by CGT » Sun Mar 10, 2019 3:17 pm
On a Stuska!
cardo0
Post by cardo0 » Sun Mar 10, 2019 6:07 pm
Thx for your detailed build. It was very interesting. But too much information! So what was peak HP and peak Torque?
CGT
Post by CGT » Sun Mar 10, 2019 7:37 pm
484 hp 465 tq
levisnteeshirt
Post by levisnteeshirt » Sun Mar 10, 2019 8:19 pm
the ultra budget build would use V6 lifters and a 010 block \:D/ \:D/
cardo0
Post by cardo0 » Sun Mar 10, 2019 8:24 pm
Whew! Thats kinda amazing for an iron head budget build on what 355 cubes. Makes me more optimistic for my Gen II LT1 build in the make. I won't use as much or even nearly as much cam though. Did you change valves? I cant see what valves your using so I assume they are stock size though I did read 1.8 installed height meaning longer stems (I think). The stock LT1 (Gen II) heads flow very similar to the vortecs but I had larger 2.00" and 1.55" valves put in my stock LT1 heads and kinda regret it. I should have opened up the chambers to unshroud the larger valves but didn't so I think the stock valves would at least have better "quality flow" with unmodified chambers.
Thx again for sharing.
randy331
Post by randy331 » Sun Mar 10, 2019 10:33 pm
1.94" valve with 52* seats ? Did I read that right ?
That may be a new HP/ valve window area record ?? LOL
So,.... low lift flow adds low rpm power ?
How much low lift flowZ could a 1.94 valve with a 52* seats have ?
Small valves don't add power below peak TQ ?
Steep seats don't either ?
Open ex valve 8*-10* earlier and close In valve 4* later?
Looks like it's short on something ?? Short on peak TQ to peak HP spread.
Did you figure what your mufflers need to flow for that engine ??
Hate to see it loose a bunch of power in the car cause of low muffler flowZ.
paulzig
Post by paulzig » Sun Mar 10, 2019 10:56 pm
The cam:
" 238 248 .525 .500 104 cam was used....Comp Marine lobes. "
I assume this is 104LSA or is it 104ICL???
CGT
Post by CGT » Sun Mar 10, 2019 10:59 pm
The cam:
104 lsa 101 icl.
paulzig
Post by paulzig » Sun Mar 10, 2019 11:02 pm
You guys need to digitize some of your ports and sell the heads :)
Rick360
Post by Rick360 » Sun Mar 10, 2019 11:54 pm
Nobody would buy them ... not enough FLOWZ :lol:
Rick
GARY C
Post by GARY C » Mon Mar 11, 2019 12:16 am
1.94 valve, minus .250 for 52 degree seat = 1.69 valve size... run that on 128 and you get a 104 LSA... Just Saying!
CGT
Post by CGT » Mon Mar 11, 2019 9:51 am
Yeah, something along those lines. That'd be 242 258 108 there.
For the sake of learning I would do Comp lobes 13064 intake 13068 exhaust on 108-110 ish. I even offered to get this cam prior to dynoing on my dime, but it turns out not everyone is as eager to rip engines apart on the dyno as I am. #-o So they weren't interested. I can't say I blame them, it wouldn't have stayed in the engine anyway, probably wouldn't be a very good daily driver cam.
I agree. I would like to see what some different valve events did to that spread, I think they are contributing to that. But it could just be something not quite shaped right in the port, not enough window area etc etc. It would be fun to find out. I think it should make more horsepower then it does from what it makes at peak torque...it just sheds torque too fast after that point. What's your thoughts?
Also more hindsight......I would have added a little more fuel up top, and I would have liked to have pulled it out to 6800-7000 for the data alone. Also the manifold was left burr finished, without that it's hard to say what it would have made :lol:
Stock valves, getting to 1.8 installed height was partly due to the beehive retainers, and partly the result of the very sunken valve job.
Also Im always happy with those Marine and HUC lobes from Comp. Valvetrain is dead quiet at idle, and very stable without much spring pressure. Not the meanest lobes out there but they work good for this kind of stuff.
CGT
Post by CGT » Mon Mar 11, 2019 10:24 am
Just got an opportunity to look through the spreadsheet. Very Nice SVT.
