Walter R. Malik wrote: ↑Sat Oct 27, 2018 11:37 am
digger wrote: ↑Fri Oct 26, 2018 10:28 pm
more likely the 5min stuff doesnt work as good. its compromised to make it set quicker. thats what ive found with epoxies in general
I was under the impression this was to be FILLER material for an intake manifold where adhesion and temperature are the only criteria ... strength is not the issue.
Now I see that everyone wants to interject their own criteria, not the OP's.
I guess I should realize, that is the normal practice here.
Adhesion strength is one of the ways in which the 5 minute version is compromised.
None of it is very "strong" structurally speaking. I wouldn't try to put threads in any of the pour-n-mix stuff unless it's something really big and coarse like a broom handle thread. The stick weld type stuff does dry hard enough that you can use it where you need to maintain a gasket surface.
The tab on the bottom is Quiksteel, hanging out to cover a port leading to the exhaust ports. Ran this manifold for years, never leaked and had no erosion.
One of my current projects is taking a manifold that someone cut the carb area out into a huge plenum, and filling all that back in so it is four holes again. Had to use a ton of the Quiksteel, and when it starts to get warm as it sets up, it gets HOT when you are working with a large amount of it! But it's the only thing I can trust to be able to be FILED down flat so the carb gasket will seal to it.
