Some also say that E10 fuel is more abrasive than non ethanol fuel and it causes valve stem wear...Microwelding of the exhaust valve and valve seat is now thought to have occurred due to the increase of flame front speed when the switch to unleaded came about. The increased combustion pressures caused 'micro welding' in older style motors that had the valve seats machined into the cast iron head. Retarding the timing of the engines reduced the combustion pressures and proved to be an effective short term measure in the switch to unleaded fuel. The long term solution was hardened steel valve seats
What do you think about these statements?
