SBC NASCAR V8 firing order
amc fan
Post by amc fan »
Does anyone know the firing order of Chevrolet NASCAR V8 engine? Is there any advantage of using it on a regular 18436572 engine for less crank fatigue and better cylinder filling?
Newold1
Re: SBC NASCAR V8 firing order
Post by Newold1 »
Firing order is still 18436572 in chevy's Nascar RO7 engine and that is mandated by the rules. If you want some better harmonic crankshaft loading, use the LS firing order, 18726543. This is what some now call the 4-7 & 3-2 swap.
amc fan
Post by amc fan »
Thanks Newold1 that is what i was looking for. Someone I know had a new cam ground with the 4-7,3-4 swap and the idle sounds a little different , and picked up little in performance.
Walter R. Malik
Post by Walter R. Malik »
Newold1 wrote: Mon Oct 22, 2018 4:43 pm Firing order is still 18436572 in chevy's Nascar RO7 engine and that is mandated by the rules. If you want some better harmonic crankshaft loading, use the LS firing order, 18726543. This is what some now call the 4-7 & 3-2 swap.
Also, Ford 351 Cleveland, 351 Windsor and 351M-400 firing order since 1969.
af2
Post by af2 »
amc fan wrote: Mon Oct 22, 2018 5:14 pm Thanks Newold1 that is what i was looking for. Someone I know had a new cam ground with the 4-7,3-4 swap and the idle sounds a little different , and picked up little in performance.
Idle yes, Performance Pipe dream
GURU is only a name.
swampbuggy
Post by swampbuggy »
AF2....would you consider the idle sound better or ?????? Mark H. :?:
Scott
Post by Scott »
Walter R. Malik wrote: Mon Oct 22, 2018 7:09 pm
" Cleveland firing order is 13726548 "
cjperformance
Post by cjperformance »
Scott wrote: Thu Oct 25, 2018 2:10 am
Think 'firing pattern', draw it out and all will be revealed.
swampbuggy
Well somebody's got to be wrong on those numbers
John Wallace
Post by John Wallace »
NO.
Diagram it?
13726548 - ford
26543187 - convert the cyl # to GM # from ford numbering
18726543 - then start at #1
John Wallace
Pontiac Power RULES !
www.wallaceracing.com
Walter R. Malik
John Wallace wrote: Thu Oct 25, 2018 7:05 am NO.
Diagram it?
13726548 - ford
YES ... the "Pattern" is the same; the cylinders are simply identified and numbered differently.
swampbuggy
Okay guys I get what you're saying now my bad. Mark H.
midnightbluS10
Post by midnightbluS10 »
This should help
JC -
Roundybout
Post by Roundybout »
Isn't there also a cooling advantage moving the adjacent firing cylinders to the front of the block?
Since 90° @ 6,000 RPM is only 2.5 milliseconds between firing #5 and #7 vs. 10 ms. until the pattern repeats, I think there's far too much thermal mass for any measurable temperature fluctuation to occur between cycles either way.
