Any good pics of ported L98, ZZ4, 113 casting heads?
Re: Any good pics of ported L98, ZZ4, 113 casting heads?
worked on them a little more last night, heres where im at so far
I did some measuring in the bowls for you. If you don't have a ultrasonic thickness gauge call it done. I did mine before I had a good one. I also knew it was a thin casting so I worked on boosting the efficiency and not increasing the volume much. Mine cc about 180cc. Thanks, Charlie
Comparison of the short side when I did this set.
Pete Graves
CPMotorworks,Inc.
Custom Engine Machining
CPMotorworks,Inc.
I scribed the port entrance with a 1205, thinking of porting it to that cause when i put a 1204 on it the gasket hung lower than the roof, theres nothing to be gained by lowering the floor correct? leave that alone besides quickly cleaning the casting flash off? Pushrod pinch was .930, should i go 1.000 or 1.050?
As you look into the Intake flange you need to kick the common wall over( widen the port) all the way down to the rear wall of the valve bowl.
Once you size your valve bowl Throat you want most of the port width to be on the common wall size of the runner as you look down into the bowl .
The straighter this wall is the better.
Here's I picture of such a reworked runner , though not in a Chevy head.
If you can't get it up or out, you gotta go down . To get the area.tchapps88 wrote: ↑Wed Oct 24, 2018 11:44 am I scribed the port entrance with a 1205, thinking of porting it to that cause when i put a 1204 on it the gasket hung lower than the roof, theres nothing to be gained by lowering the floor correct? leave that alone besides quickly cleaning the casting flash off? Pushrod pinch was .930, should i go 1.000 or 1.050?
For reference my ports are 2.010" x 1.210" with a 1.100" pinch. SSRH is .800". There's nothing to be gained on the floor if the shape is correct.tchapps88 wrote: ↑Wed Oct 24, 2018 11:44 am I scribed the port entrance with a 1205, thinking of porting it to that cause when i put a 1204 on it the gasket hung lower than the roof, theres nothing to be gained by lowering the floor correct? leave that alone besides quickly cleaning the casting flash off? Pushrod pinch was .930, should i go 1.000 or 1.050?
Pete Graves
CPMotorworks,Inc.
CPMotorworks,Inc.
The stock port wall at the head bolt on the common wall is like .180" thick and with taking very careful measurements you want to grind that back to .060" to straight out the wall.
think im gona call this good, went back and trimed down the guide area some more, knocked down the bolt buldge but didnt get agressive as i didnt want to break through, opened up the pushrod pinch to 1.050, did the top and sides to a 1205, left the floor alone its .080 away from 1205 gasket line. if it hit 225cfm at .500 i will be happy.
Was that Wheet's bench?
Here is what mine flowed. Carbon copy.
Yes it was, way back in 2010! They went on a 406 in an '85 Iroc even lolSpeierRacingHeads wrote: ↑Tue Aug 27, 2019 4:54 pmWas that Wheet's bench?
Pete Graves
CPMotorworks,Inc.
CPMotorworks,Inc.
Nice work. Do you think the L98 083 iron castings will flow about the same with the same port work? This is my first attempt porting heads so I figured I would give it a try.
https://www.google.com/url?sa=t&source= ... hTvz_DG2YS
See if this helps. Charlie
