383 combo in Enginepro
I’m building a 383 for Chevy truck. I put everything in enginepro and it doesn’t spit out the numbers I expected. I’ve seen several combos discussed here that show better numbers and a lower rpm peak torque number.
.040” 3.75 with 6” rods, intake flow of 260 cfm
248 duration @ .050 HR. cam specs it ask for are limited.
Single plane intake
10.8 CR
770 CFM carb
Shows 421 ft-lbs @ 4700
I need this thing to be streetable and make torque at low rpm with a good torque curve
Any help or advise will be greatly appreciated.
Single plane intake
10.8 CR
770 CFM carb
Re: 383 combo in Enginepro
IMO a bit big on duration for strong torque down low. Think 230's and an RPM Air Gap intake manifold !
If this is for a truck used for daily driver and towing?Raybo wrote: ↑Mon Oct 15, 2018 4:08 pm I’m building a 383 for Chevy truck. I put everything in enginepro and it doesn’t spit out the numbers I expected. I’ve seen several combos discussed here that show better numbers and a lower rpm peak torque number.
Single plane intake
10.8 CR
770 CFM carb
No towing just street driven performance oriented. 2800 stall turbo 350 3:55-3:73 gears
What numbers do you want?Raybo wrote: ↑Mon Oct 15, 2018 4:08 pm I’m building a 383 for Chevy truck. I put everything in enginepro and it doesn’t spit out the numbers I expected. I’ve seen several combos discussed here that show better numbers and a lower rpm peak torque number.
Single plane intake
10.8 CR
770 CFM carb
I’m going to have a custom cam ground but wanted to select the heads now. Looking at Dart aluminum 65cc with 180 runners
Shooting for 450-475Headguy wrote: ↑Mon Oct 15, 2018 4:47 pmWhat numbers do you want?Raybo wrote: ↑Mon Oct 15, 2018 4:08 pm I’m building a 383 for Chevy truck. I put everything in enginepro and it doesn’t spit out the numbers I expected. I’ve seen several combos discussed here that show better numbers and a lower rpm peak torque number.
Single plane intake
10.8 CR
770 CFM carb
fairly large cam and small head runner is likely where your program is coming up with lowish torque numbers. 195-200cc head and ballpark 235degr cam will likely show you better numbers, and be a bit more pleasant to drive.
I was just about to comment pull 10-12 degrees out of the cam and that 200 cc head will make what you are looking for
Awesome. Appreciate the input
