331 sbf dyno results today
grant6395
Post by grant6395 »
331 sbf
Afr 185s
Ported victor jr
Quick fuel 750 double pump
Jones hydraulic roller 232/236 .576 108 sep.104 icl
10.7 compression. Mahle 1.0 mm rings. 2mm oil.
Max 1.5 cfm on the blowby meter during run.
Power peaked at 6800
502 hp/. 445 lb feet. All with break in oil.
1 1/2 primaries.2.5 collector. Tried larger 1 5/8
3.0 collector. 5 hp gain is all.
A/f tuned to 12.6 ish.
PRH
Re: 331 sbf dyno results today
Post by PRH »
Nice numbers, and interesting results from the header hest.
JoePorting
Post by JoePorting »
Nice numbers too. I would have guessed 425 hp.
Joe Facciano
grant6395
Post by grant6395 »
I was pleasantly surprised also. I thought about 1.3 per inch would be the norm for these type of street engines. We were blessed with accurate o2 sensors for a change on the dyno, and ended up with a 6 jet size spread to get them as even as possible. This was with a crappy 12 by 3 inch air cleaner on it also. ( with picked up 8 hp. Lol. ) 94 octane pump fuel. The headers shocked me a bit. I thought the larger tube would prevail by a bunch. But it didn’t. A thank you to mike jones is in order. His lifters and cam worked well.
JoePorting
Headers and compression is overrated.
Joe Facciano
digger
Post by digger »
Out of curiosity how did the curve change with headers ?
travis
Post by travis »
Excellent results!
I’m very curious about the headers myself. Was these long tubes or shorties?
ozyfordman
Post by ozyfordman »
X2 for the results and am also interested with the headers. How much mismatch at the port with the small primary? Tri-y or long tubes, stepped? Collector length and diameter? Do the specs agree with Pipemax?Was there a down turn from the port or more like dyno/ boat/ Hotrod headers? Just curious as need to build headers for Hotrod with 2v Cleveland with 1.625 primaries. Great work on a stout combination that should have good manners.
mag2555
Post by mag2555 »
Nice results there!
Looks like your averaging about 245 Intake cfm to make that 500 hp.
grant6395
Post by grant6395 »
The headers were a hooker 1.5 diameter primary designed to fit a mustang ll. They turn off the head immediately. No step , long tube/2.5 inch collector.belive me, I rolled my eyes when the customer showed up with them. But, you just never know until you test it. The second set were nothing trick either, just larger tubes 1 5/8 and a 3.0 collector.
JohnsnsFord2@aol.com
Post by JohnsnsFord2@aol.com »
That is very interesting results on the headers....
Stephen Johnson #2162
Horace Johnson #2167
SS/D 427 Ford Fairlane NHRA-IHRA
Ex-Jim Van Cleve
1985 Mustang GT N/A 331
CamKing
Post by CamKing »
grant6395 wrote: Sun Oct 14, 2018 10:30 am The headers were a hooker 1.5 diameter primary designed to fit a mustang ll. They turn off the head immediately. No step , long tube/2.5 inch collector.belive me, I rolled my eyes when the customer showed up with them. But, you just never know until you test it. The second set were nothing trick either, just larger tubes 1 5/8 and a 3.0 collector.
Which were closer to the size/area of the exhaust port at the flange ?
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
Frankshaft
Post by Frankshaft »
Fuel flow in lbs/hr and, bsfc's available?
grant6395
Post by grant6395 »
CamKing wrote: Mon Oct 15, 2018 10:59 am
They both were close to the exit size, as my customer ground out the inside weld and welded the outside.
grant6395
Post by grant6395 »
Frankshaft wrote: Mon Oct 15, 2018 11:43 am Fuel flow in lbs/hr and, bsfc's available?
I would have liked that info but our fuel flow meter was on the fritz.
