Fully ported intake
redliner
Re: Fully ported intake
Post by redliner » Thu Oct 11, 2018 8:23 pm
cjperformance wrote:
Thu Oct 11, 2018 8:11 pm
* = S p i e r id think
YEp but they wont post it typed regular with no spaces
Frankshaft
Post by Frankshaft » Thu Oct 11, 2018 8:56 pm
Depends which manifold. You could do a fully ported Victor Jr. and it would make less power than an otb Super Victor 2. A dominator on a good manifold will be up compared to a unported and 850 combo, but again, depends which manifold.
Post by MadBill » Thu Oct 11, 2018 9:25 pm
OK, got it: One of the "Disappeared."
GARY C
Post by GARY C » Thu Oct 11, 2018 10:00 pm
Thu Oct 11, 2018 8:13 pm
Because if you type it without spaces you just get an *
Eg *
Wow I didn't know that...
rustbucket79
Post by rustbucket79 » Thu Oct 11, 2018 10:27 pm
If your short times are less than stellar a large carb and intake could make it worse. You could have better results working on your clutch.
WeingartnerRacing
Post by WeingartnerRacing » Thu Oct 11, 2018 11:49 pm
redliner wrote:
Thu Oct 11, 2018 8:22 pm
WeingartnerRacing wrote:
Thu Oct 11, 2018 7:18 pm
Fully ported will be 20-30hp better.
Even at my rpm range? or is it a higher rpm thing?
Yes many stock intakes leave a lot on the table. If you were below 5500rpm it would gain next to nothing.
Eric Weingartner
Weingartner Racing LLC
918-520-3480
www.wengines.com
rewguy
Post by rewguy » Fri Oct 12, 2018 12:28 am
More hp technically should always win if gear and converter are optimized for it. But if they are NOT optimized...... then overall average power would likely win.
mag2555
Post by mag2555 » Fri Oct 12, 2018 12:22 pm
Fully ported by a average guy at home and the same done by a shop that does such as a specialties will show a 10 hp spread!
CGT
Post by CGT » Fri Oct 12, 2018 12:54 pm
redliner wrote:
Thu Oct 11, 2018 1:34 pm
(3100 lb drag car)Would a 414 sbc with 11.5-1 compression and a cam that is done at 7000 heads that are 2.5 @ pinch be quicker with a fully ported and modified plenum manifold and a Dominator or an as cast manifold and a 850 carb? Just looking for thoughts...
Whats the car run now?
"You can't make any power with the valves closed!"
Big brained Internet guy
Joe-71
Post by Joe-71 » Fri Oct 12, 2018 1:06 pm
What is your vacuum reading at the end of the quarter? During the run? If you are above 1.0" of vacuum, you may benefit from the Dominator. I have found that a well prepared plenum will increase the airflow by 30 cfm in many intakes, without touching the runners' exits. Need to prepare the air and fuel to turn into the runners, and do so without slowing it down or turbulence.
redliner
Post by redliner » Fri Oct 12, 2018 1:10 pm
Best so far is 1.447, 4.150,6.448,106.44 8.446,10.148,131.69 in the Midwest, Cordova Dragway, 3100 lbs, Liberty TKO 600
redliner
Post by redliner » Fri Oct 12, 2018 1:12 pm
I do nt know vac. readings but am running a Mark Whitener 1050 Dominator on S p e i e r modified Motown intake.
Frankshaft
Post by Frankshaft » Fri Oct 12, 2018 2:20 pm
I will be at Cordova this weekend. Hopefully they prep the track well.
redliner
Post by redliner » Fri Oct 12, 2018 2:28 pm
I am out for the year having busted my trans AGAIN! What car do ya Run Frank? I might come down. I live 14 miles north of the track
user-17438
Post by user-17438 » Fri Oct 12, 2018 2:29 pm
Me too :wink:
