Maximum lifter bore size for factory Ford 302 block
groberts101
Post by groberts101 » Mon Oct 08, 2018 5:42 pm
Simple question. Can a stock 1974 Ford 302 block accept a 1.060" OD keyway style lifter bushing?
And what if the main oil gallery has been punched out to 1/2"? Anyone installed larger OD bushings in a stock 302 or 5.0 block or know what the maximum lifter bore diameter limits are while still avoiding the main oil supply passage?
BILL-C
Re: Maximum lifter bore size for factory Ford 302 block
Post by BILL-C » Mon Oct 08, 2018 10:31 pm
Jesel custom shop makes special bushings to keep oil where it belongs if you break through. Somewhat common issue on certain sb chevy blocks.
Carlquist Competition Engines
mag2555
Post by mag2555 » Tue Oct 09, 2018 6:01 am
No one makes a Mushroom type lifter for the Ford?
groberts101
Post by groberts101 » Tue Oct 09, 2018 7:56 am
Thanks for the timely reply, Bill. Been talking with CHE on the matter and they didn't mention the shortened oil band so will call again today.
groberts101
Post by groberts101 » Tue Oct 09, 2018 8:02 am
Looking to use up some shelf parts. Existing bores are sloppy so it was buy new parts and bore to heavier .904 link bar style or buy bushings. I have Wyndorfs keyway indexing tool already so this seemed like the cheapest and most logical way to go until my aluminum block bullet is done.
Charliesauto
Post by Charliesauto » Tue Oct 09, 2018 5:20 pm
.904" lifters can use a 1.002" OD bushing which is no problem is stock block.
BILL-C
Post by BILL-C » Tue Oct 09, 2018 6:32 pm
We have bored many stock .875 lifter bores out to .904 no problem. No bushings to buy, just labor. Much cheaper.
groberts101
Post by groberts101 » Mon Oct 15, 2018 9:16 pm
Thanks for the replies. CHE is making me a custom set of keyway bushings.
