2009 6.0 balancer sleeve question..
Does anyone make a harmonic balancer repair sleeve for a 6.0 LS engine? Normally I would get a new balancer but the customer installed a supercharger and drilled the balancer for two dowel pins and I don't have the tool.
- MadBill
Re: 2009 6.0 balancer sleeve question..
Is the issue is a seal wear line on the damper sealing surface? If so another alternative is an offset seal.
- New Member
Call Silver Seal. This is where most of the repair sleeves come from.
1-800-521-2936
Dan
S.W. MI
1-800-521-2936
Dan
S.W. MI
- Location: Chancellorsville Battle Field, Chancellorsville, Virginia
Speedy Sleeve also.
