Re: Winner Of The Race Engine Challenge
Posted: Thu Oct 11, 2018 12:19 pm
Ok yes see what your saying. Street/strip class so to speak.
Home of Racing's Best and Brightest
https://www.speed-talk.com/forum/
You would still need to be 100% accurate at the 1% 10 point deduction, before going into the 2% and over DQ territory.CamKing wrote: ↑Thu Oct 11, 2018 12:02 pmNot when the competition doesn't have the ability to be 100% accurate when tech'ing the engines.
I was in charge of checking the .775" valve lift rule. Luckily, neither were close to .775".
When checking the lift at the retainer with a dial indicator, if the indicator is not 100% parallel to the valve guide, the indicator will read higher then it should.
With your way of thinking, if I measured .7751", I would have to DQ the engine. I've measured more cams then almost anyone, but with the equipment we have to work with, I can''t be 100% accurate.
What I've proposed for next year, is a penalty of 10 points for being under 1% over, 50 points for being 1-2% over, and DQ'ed for over 2%.
I think there should be a point penalty for being over the limit, even a small amount. That way most people will not try and push the limit.gmrocket wrote: ↑Thu Oct 11, 2018 12:24 pm
You would still need to be 100% accurate at the 1% 10 point deduction, before going into the 2% DQ territory.
There would still be a hard limit. Does it matter at that tipping point , or if it's 12:1 max?
It would be the same as saying max comp is 1% under 12, if you go over that 1% you out.
That's still a number used to justify it being within the rules
Whether everyone shoots for the max 12, or 1% over , which I guarantee will happen. You still have that point, it's ok or not.
No sense in complicating things. If it's over, your DQd, end of story. It's not a judgment call, it's simple measurements and math. This is basic engine blueprinting!CamKing wrote: ↑Thu Oct 11, 2018 12:32 pmI think there should be a point penalty for being over the limit, even a small amount. That way most people will not try and push the limit.gmrocket wrote: ↑Thu Oct 11, 2018 12:24 pm
If the limit is 12:1, and they end up 12.1:1 they lose 10 points. I can tell you, that extra .1 of compression is not worth 10 points.
We made extra sure that we weren't on the limit with our engine. Every hard rule, we were quite a margin away from the limit simply because of this. Way under on compression (too much so actually), way under on valve lift, and everything else that was measurable. We were 1/2 a point under on compression. What is another .4 compression points worth in power?Warp Speed wrote: ↑Thu Oct 11, 2018 12:57 pm
If the limit is 12.1, 12.04 is the tolerance. This gives a little room for componant temp and carbon and the human factor. Even in our ultra competative situation, I don't think we let anything out the door over 11.94. That is the longest stroke, smallest chamber ect. Worst case. It's like that in any limited class racing.
I will answer that.
YES .pamotorman wrote: ↑Thu Oct 11, 2018 11:57 am did they count the volume between the top ring and the top of the block and add it to the gasket and head chamber volume ?? no one answered my question
I never decked this block.Warp Speed wrote: ↑Thu Oct 11, 2018 12:05 pmI understand what your saying Stan, but a .010 piston to deck height error..............from a proffesional?Stan Weiss wrote: ↑Thu Oct 11, 2018 11:10 amJay,
I look at this totally different. 14.1:1 for me means either the person was cheating or incompetent. 12.13:1 to me looks like just an honest mistake. Both illegal but to me a big difference.
Stan
Especially entering into a class competition with stated rules in that area. Good thing it wasn't a customers who class races!
This is one area where most engine builders push the limits to get the most out of a build.
Hahaha, I've made plenty of mistakes. But measuring piston to deck clearance on every hole is pretty basic engine blueprinting. Just like pouring every chamber, and going off of the smallest.Walter R. Malik wrote: ↑Thu Oct 11, 2018 1:39 pmI never decked this block.Warp Speed wrote: ↑Thu Oct 11, 2018 12:05 pmI understand what your saying Stan, but a .010 piston to deck height error..............from a proffesional?Stan Weiss wrote: ↑Thu Oct 11, 2018 11:10 am
Jay,
Stan
It was a previously built "restricted" NASCAR CUP engine block which I got honed to get the bores right and yes, it is my responsibility to not presume the decks would be correct.
I screwed up, it is over.
I am glad to read that you have NEVER made a mistake in you life which cost you.
I agree.No sense in complicating things. If it's over, your DQd, end of story.
I don't know who originally said this and, I don't understand why.
How do you define "full operating temps"?
