Maraging steel retainers use
The Badger
Post by The Badger » Fri Oct 05, 2018 5:38 pm
Hi everyone, got a set of retainers on the way from a friend of mine. Turns out they are maraging steel retainers from a cup engine from what he told me and they run top lock keepers.
Did a little digging (aka typed the keywords into google)
And found out they are lighter than the titanium retainers I've been using lately. I was wondering
1 the fact they are used will there be anything specific for me to check on these?
2. Is this material durable for street, drag racing, etc etc?
The sizes he us sending me would go in at least one strip build I'm doing and possibly another street strip I'm trying to make for hot rod drag week.
Thanks again for any advice.
Newold1
Re: Maraging steel retainers use
Post by Newold1 » Fri Oct 05, 2018 6:29 pm
Maybe Warp can enlighten us, if they don't shoot him first!
The Badger
Post by The Badger » Fri Oct 05, 2018 10:03 pm
Hopefully him or someone else can chime in, I didn't know this stuff was around until recently.
swampbuggy
Post by swampbuggy » Sat Oct 06, 2018 10:03 am
Badger, that steel is an exceptionally high grade blend of a few different metals. It is very strong yet malleable enough not to break/crack. I would not hesitate to use them after a close inspection with 10 power magnification. There is MPO. Mark H.
The Badger
Post by The Badger » Sat Oct 06, 2018 1:48 pm
I talked to friend today, said he has always thought they were maraging steel, said they weigh under 13 grams each, size is 1.230"x .680. Said he got them from Childress racing. What else other than maraging steel could it be? He said it is a steel and not titanium
swampbuggy
Post by swampbuggy » Sat Oct 06, 2018 9:00 pm
(Tool Steel) is common for folks who want a retainer stronger and harder than titanium at only a very slight increase in weight. Valve springs or dampers (if) they are used will not cut into tool steel. Mark H.
grandsport51
Post by grandsport51 » Sun Oct 07, 2018 3:35 pm
Neat Product
LIGHT 'EM UP
grandsport51
Post by grandsport51 » Sun Oct 07, 2018 3:36 pm
Forgive me wrong pic
LIGHT 'EM UP
BOOT
Post by BOOT » Sun Oct 07, 2018 6:42 pm
Just to be clear is Maraging steel the same as Tool steel?
grandsport51
Post by grandsport51 » Sun Oct 07, 2018 7:14 pm
No carbon in the Maraging Steel unlike H-11
LIGHT 'EM UP
GerryP
Post by GerryP » Sun Oct 07, 2018 9:22 pm
No. Maraging steel is what you might call an exotic alloy. You might just take a gander and the price of H11 retainers and compare them to Maraging steel retainers. They do a good job of thinning your wallet. Were you would use it is in an application you needed the weight of Ti but the strength/endurance of H11.
j-c-c
Post by j-c-c » Thu Oct 11, 2018 6:48 pm
It would seem to me that in a specialized purpose high budget application, like WC, they would be made just strong enough to achieve the task and life cycle, and little more, thinking they would get tossed after the race on a rebuild. Why does the OP feel confident there is additional life in a used race part without risk? Dropping a valve is a bad thing, right?
Warp Speed
Post by Warp Speed » Fri Oct 12, 2018 5:07 am
The retainers the op is speaking of, will more than likely out live the vehicle! Lol
j-c-c
Post by j-c-c » Fri Oct 12, 2018 9:50 am
All 16? :shock: :D
Warp Speed
Post by Warp Speed » Fri Oct 12, 2018 9:58 am
All 16? :shock: :D
Yep :wink:
