big chevy connecting rod reccomendation
rewguy
Post by rewguy » Tue Oct 02, 2018 9:45 pm
4.250 stroke, std. deck block, howards pro max 46cc domed pistons(not sure on exact weight....but figure average weight like an srp or such), Id like to shift at 7600-7700, and cross at the same or a tick higher......Do I have to spend 1500+ to feel comfortable or will a 500-700$ rod suffice? grudge race on weekends type of car.
cjperformance
Re: big chevy connecting rod reccomendation
Post by cjperformance » Tue Oct 02, 2018 10:17 pm
In my experience with BBF running up to 4.3" stroke the $500/700 H beams with 8740 or 2000 bolts will hold up fine with that use. Yes its pishing the limit in my opinion but they hold up. That said if using an expensive or rare block , crank heads etc i would say go for the more expensive/stronger option
randy331
Post by randy331 » Tue Oct 02, 2018 10:26 pm
Only you can decide your cost vs comfort level. LOL
I got a set of Callies Comp star rods in a BBC 4" stroke that is in a pulling truck.
Rev limiter at 8800 rpm right now and it's bumped it sometimes.
I got another one out in same application with Oliver rods, but only dyno time and 3 pulls now.
I went with the Callies Ultra rods in our own pulling truck, for the very thing you mentioned. (comfort vs cost) I felt the cost was worth the comfort when I hear my son running our truck. LOL But ours regularly spins over 9000 rpm.
But one of the guys we pull with is running Scat crank and rods in a Big Block Dodge and is on his third year without tear down. He doesn't turn it over about 8400-8500 but it's still the same application.
Your application less stressful than a pulling truck.
So that comfort level isn't the same for everyone.
it seems some run cheap junk and get away with it while others have trouble with good parts.
Sorry, my post probably didn't help. LOL
cjperformance
Post by cjperformance » Tue Oct 02, 2018 10:31 pm
^^^ yeah I've seen those pulling truck vids Randy, higher stress level for dam sure!! Lol
Mark O'Neal
Post by Mark O'Neal » Wed Oct 03, 2018 12:58 am
Tuneups break most parts.
cjperformance
Post by cjperformance » Wed Oct 03, 2018 1:03 am
Oh so true !!
MELWAY
Post by MELWAY » Wed Oct 03, 2018 1:24 am
Callie’s Compstar. Or Tom molnar H beam will work well for you
Mark O'Neal
Post by Mark O'Neal » Wed Oct 10, 2018 2:24 am
Oh so true !!
The other way to put that is "Bad tuneups put my grandson through Notre Dame."
cjperformance
Post by cjperformance » Wed Oct 10, 2018 4:50 am
Oh so true !!
Ouch!
mag2555
Post by mag2555 » Wed Oct 10, 2018 6:13 am
Run over your own engine oil on the track at 140 plus miles an hour , or on the street at 80 mph and you will very likley instantly see the value and logic of spending another 400 bucks on the Rods you should have had in the motor!!!!
Your very selfish building a motor this way to race on the street!
On the strip chances are pretty good you just hurt yourself and your property , on the street you will hurt others and there property!!
I have seen this pain and distruction happen not just once , but twice within a week watching Bronx NY street racing in the mid 70s!
Mark O'Neal
Post by Mark O'Neal » Wed Oct 10, 2018 10:55 pm
We had Chinese rods in the 1970s?
Well, I guess I can still learn new things.
numboltz
Post by numboltz » Sun Nov 25, 2018 1:00 pm
[no technical value]
If Chinese rods were as well made as Chinese wimmin, block sales
would take a major dump. :shock: Just saying.
rustbucket79
Post by rustbucket79 » Sun Nov 25, 2018 1:36 pm
when did offshore H beams become so unreliable? Way overkill in most applications.
bigmike
Post by bigmike » Sun Nov 25, 2018 1:48 pm
LOL I guess President nixon must have brought a bunch of connecting rods back when he visited china in 1972. :mrgreen:
Newold1
Post by Newold1 » Sun Nov 25, 2018 2:50 pm
My 2 cents.
The Molnar rods with ARP 2000 bolts will give you all the comfort you need on a well built short block and a good top end.
