Engine simulation software
Caprimaniac
Re: Engine simulation software
Post by Caprimaniac » Tue Oct 09, 2018 4:10 am
DD2000 and 2003 can be downlodad via torrents or other. I got the 2000-version via Pirate bay- RIP- and it for sure runs on Windows 10.
I find it easy to use, and output sensible- at least With a N/A engine. I had trouble trying to runa SS or TS engine.
Are the newest/current Version DD5?
mk e
Post by mk e » Tue Oct 09, 2018 7:52 am
Yes but 6 is in limited release and has been for ....6 months or longer so it should be coming soon. I have it and it has some nice updates like now it lets you tell it what rpm you want the exhaust tuned for and it spits out the pipe lengths and diameters it chose. I forget what else is in there but I like that feature. Dynomation6 got a bunch of updates too.
Mark
Mechanical Engineer
mk e
Post by mk e » Tue Oct 16, 2018 9:19 am
Version 6 just got a bunch more features and a major makeover. ....so everything I said about the FE model ( desktop dyno) being high is now wrong.
On my engine FE is now reading 864hp vs about 1020 in yesterday's version. The wave model now reads 880 vs about 950 yesterday. 850-900 is where I think it will be when I finally get it running right and to the dyno so as sad as I am to see lower estimates I think they are probably closer to real.
There is a new screen the spits out what it thinks the optimal min port area should be....it says mine are a bit small which is also what pipimax tells me so that seems to match.
Mark
Mechanical Engineer
mk e
Post by mk e » Tue Oct 16, 2018 9:38 am
When I open the same screen, simulator lrun log, in the FE model it gives me what it thinks is optimal for the intake and exhaust dimension.....very pipemax like.
Mark
Mechanical Engineer
Dave Koehler
Post by Dave Koehler » Tue Oct 16, 2018 12:11 pm
I use Performance Trends Engine Analyzer Pro with Pipemax for a second opinion.
mk e
Post by mk e » Tue Dec 11, 2018 9:21 am
I just saw that DM6 and dynosim6 are now available in general release and are better than 5. DynoSim now has a simple wave calculation baked into it so a pretty big change from the last version. Desktopdyno is still v5
Mark
Mechanical Engineer
justanothermelvin
Post by justanothermelvin » Sun Mar 24, 2019 3:50 am
Over the last ten years, I've purchased and used the Desktop Dyno, Pipemax, Controlled Induction 2020, Engine Analyzer Pro and Dynomation. I have found that Controlled Induction 2020 is by far the best software for determining the correct camshaft. It will even generate the actual profile lift tables, which I can load into Engine Analyzer and/or Dynomation to evaluate the cam and make any necessary adjustments.
The CI 2020 cam requirements have never been more than 1% to 1.5% from any final cam design numbers. However, Controlled Induction took me a few days to understand, as it re-arranged my views on camshafts.
rebelrouser
Post by rebelrouser » Sun Mar 24, 2019 5:24 pm
My vote as well, I use both programs, very satisfied with results, IF you take the time to put in good numbers.
plovett
Post by plovett » Sun Mar 24, 2019 5:44 pm
What I want is two or more data points for cam duration in a reasonably priced program.
JMO,
paulie
Dave Koehler
Post by Dave Koehler » Sun Mar 24, 2019 6:57 pm
What is reasonably priced?
plovett
Post by plovett » Sun Mar 24, 2019 8:33 pm
Less than $150?
Dave Koehler
Post by Dave Koehler » Sun Mar 24, 2019 10:34 pm
That may be reasonable but it's not realistic.
F-BIRD'88
Post by F-BIRD'88 » Mon Mar 25, 2019 12:24 am
If when using the DeskTop Dyno program if you enter the expected…/estimated actual induction cfm at max power instead of the rated cfm of the carb used (eg: 750 cfm @1.5" ), you get a much more realistic result.
I like Engine Analyser Pro.
plovett
Post by plovett » Mon Mar 25, 2019 12:54 am
Why is wanting one more cam duration data point unrealistic?
Stan Weiss
Post by Stan Weiss » Mon Mar 25, 2019 1:08 am
Since I do not have dynomation I am not sure what it does with the data, but I know it will read in CamDr / CamPro / S96 format files.
Stan
Stan Weiss / World Wide Enterprises
Do you use engine simulation software that uses cylinder head flow files?
We have a package of more than 3025 DFW or FLW Files
