Brake in procedure
swampbuggy
Re: Brake in procedure
Post by swampbuggy » Fri Oct 05, 2018 1:40 pm
GT 50 wanted to make sure you fully understand what i was saying about the seat the rings deal. Accelerate from 2000 or 2500 to 4000 rpm's then completely back off the throttle, decel back to appx. 2000 then repeat. No need to push to WOT especially if you are using a carb. which would dump maybe excessive fuel on the rings. Hope this helps ! Mark H. :)
Newold1
Post by Newold1 » Fri Oct 05, 2018 3:33 pm
Cjperformance said all that needs to be said!
