id of mid 60s327 engine
chevy art
Post by chevy art » Thu Sep 27, 2018 3:34 pm
im helping my buddy do a 327 sbc and i dont know what it stsrted out as(HP?} can any one ID this engine with this code that is stamped on the front pad on pass, side of engine# TI202MK(2nd digit is an alpha I) cast code on back of block id 3903352. thanks you art in NY
tenxal
Re: id of mid 60s327 engine
Post by tenxal » Thu Sep 27, 2018 3:51 pm
'67 327-275 manual trans.
chevy art
Post by chevy art » Thu Sep 27, 2018 3:56 pm
yhanks tenxal any idea which chevy model car it was in art
tenxal
Post by tenxal » Thu Sep 27, 2018 4:04 pm
MK's were Camaro and Nova. 327-275 horse, small chamber 1.94-1.50 heads, .390/.410 hydraulic cams, cast iron intake with a QJet, flat top pistons with 4 valve reliefs.
chevy art
Post by chevy art » Thu Sep 27, 2018 4:14 pm
thanks ten that was quick. i know the engine. as i am a chev2 guy and this is an engine that is run in the stock and SS class and run fast. same in the camaros art
PackardV8
Post by PackardV8 » Thu Sep 27, 2018 4:26 pm
Since they were only offered with manual transmission, Tonawanda legend has it those were built and rated at 275hp because they fit some then-current NHRA class especially well.
tenxal
Post by tenxal » Thu Sep 27, 2018 7:44 pm
Yes it is. :wink: A little trivia: the '66 327-275's have a different cam than the '67 and '68's. Also, the '66's can use either a small 1.500/1.500 Holley, an AVS or QJet. The '67-'68's can only use the QJet.
PackardV8
Post by PackardV8 » Thu Sep 27, 2018 8:15 pm
As long as we're going down this long-lost-dead-end road, what were the differences between the '62 250hp, the '66 275hp and the '62 300hp? I remember a few.
Bonus question - how many horsepower ratings were there for the 327"? I recollect the 210, 235, 250, 275, 300, 340, 350, 360, 365, 375; what else can you remember?
Tie breaker - did Chevrolet ever offer more different horsepower ratings for any one displacement?
fdicrasto
Post by fdicrasto » Thu Sep 27, 2018 8:33 pm
Here is a little info. The 62 250 hp had small valve heads and a rochester 4 bbl. The 62 300 hp had the "461" 1.94" int and 1.50" exh. valve heads and a carter AFB 4 bbl. 66-67 nova/chevy II engine blocks were all alone because of oil filter deepened location due to location for stick shift pivot ball for cross shaft location. Grumpy also said these blocks had a higher percentage of nickel also. I will add more later if needed.
peejay
Post by peejay » Thu Sep 27, 2018 8:42 pm
I would think that the 350 would have a significant number of horsepower ratings, given that it existed through the dark days when American automakers were trying to figure out how to make engines run clean, and horsepower ratings changed practically every model year as they made steps forward and steps back. As a bonus, it straddled the change between gross ratings and net.
They DID make the 3.48" stroke, 4" bore engine from the late 60s through the late 90s, after all. From Rochester carbs to Vortec fuel spiders and everything in between. (Say, does the LT1/LT4 count? Same displacement, after all)
tenxal
Post by tenxal » Thu Sep 27, 2018 9:20 pm
And then there was the '68 327-250. It had the 307's 1.75/1.50 69 cc heads, 4 valve relief flat tops, .390/.410 cam and cast iron intake with a QJet. These were available in the Chevelle and full size cars only.
tenxal
Post by tenxal » Thu Sep 27, 2018 9:26 pm
Don't forget the '67 327-325 L79 (Chevelles only) and the '68 327-325 L79. The '67 had the same alum. intake and 585 Holley that the '66 327-350 L79 did but was rated 25 hp less. The '68 327-325 L79 (Chevelle and Chevy II only) had a cast iron intake and QJet.
Post by pdq67 » Thu Sep 27, 2018 9:49 pm
I have a '64 327 AFB stock cast iron intake in my garage! I think that it is a one year intake! And fwiw, I do figure that it is the best stock intake made back then until the Z-28 hi-rise came out.
Now what is this the 275 HP/327's had a different cam in them than the old -929??
Please post back said cam's spec's so I will learn something.
Heck, my bought new '67 350SS Camaro engine had the old 283, -929 hy-cam in it stock.. I let my Buddy, "Nut's", put a -151, 350Hp/327 cam in it and it woke right up!!
tenxal
Post by tenxal » Fri Sep 28, 2018 7:37 am
Now what is this the 275 HP/327's had a different cam in them than the old -929?? Please post back said cam's spec's so I will learn something. pdq67
The '66 327/275's had the .399-.399 cam....same as used in the 283/220, 327/250 and 327/300.
The '929' cam (.390-.410) did not come into use until 1967 in the 327/275. It was developed for the '67 350/295 Camaro engine and thus became the defacto cam for virtually all hydraulic lifter small blocks.
tenxal
Post by tenxal » Fri Sep 28, 2018 7:43 am
I have a '64 327 AFB stock cast iron intake in my garage! I think that it is a one year intake! And fwiw, I do figure that it is the best stock intake made back then until the Z-28 hi-rise came out. pdq67
The pre-EGR cast iron QJet intakes outflow the cast iron AFB intake by a considerable amount. The post EGR cast iron QJet intakes are even better.
