FuelTech question
FuelTech question
https://www.fueltech.net/products/ft500 ... ge-builder
Has anyone here used one of these or any of this companies products? It looks pretty good and am looking for some real world experience.
-Carl
-Carl
Re: FuelTech question
They have a long list of customers on Facebook going back three years. You could friend several of them and ask if things are continuing to go well?In-Tech wrote: ↑Mon Sep 24, 2018 4:03 pm https://www.fueltech.net/products/ft500 ... ge-builder
https://www.facebook.com/pg/FuelTechUSA/reviews/
Thanks for the link Kevin. I am not a member of any social media, but, it did let me read a few reviews before it prompted me to sign up.
My biggest question is in regards to day to day use and how it compares to others in the aftermarket as well as GM controllers as far as repeatability. It appears to be very user friendly which is always a plus. Another question would be, if I had an ecu failure(it happens, ie lightning strike boats all the time) will a new ecu run exactly the same with my previous calibration? Stuff like that
-Carl
-Carl
The most reliable and capable I have found are the FAST XFI.
http://www.fastchip.com/
SS/JA 4156
SS/JA 4156
Maybe years ago but lots of better, faster stuff out there now from what I see.
Engine Builder, Accel, AEM, Comp, Erson, Holley, and Lunati Dealer
I think the Holley HP efi and Dominator efi ecm systems are about the best out there! JMO
- midnightbluS10
It can't be too difficult. Big Chief aka Justin Shearer uses it on his 3k? hp, methanol burning Bulter Pontiac. So it's very capable, apparently. There's a few people using their stuff. I'm drawing a blank as far as who, other than Shearer, though.
I believe Dave and Ryan Martin use it on their PLR-built bullets, as well.
JC -
I have worked with most systems. I would be interested how you think one system is faster than another? Since 36 (for instance) degrees spark advance is 36 degrees, no matter which system is used. 13-1 A/F is 13-1, no matter which system is used. The new COPO Camaro race cars I have tuned came with the new Holley system. Not crazy about it, more limited than the FAST XFI that I use in my race car. Something I have done for years, and never had a car that did not respond to: More timing in low gear, back it up in second gear, and back it up to what it likes on the dyno in high gear. Long time friend Mike Edwards did the same thing in his Pro Stock car, using a programmable MSD Ignition box, that is illegal in my Supe Stock car. I can do it with the FAST XFI, but not a Holley. Talked to the Holley rep (wanted to try that in one of my friend's COPO. Holley rep says no, he never heard of doing that. Doesn't get out much, I'm guessing.Cutlassefi wrote: ↑Sun Oct 07, 2018 8:36 pmMaybe years ago but lots of better, faster stuff out there now from what I see.
One system makes more power than another? More like options, and the tuning.
SS/JA 4156
SS/JA 4156
Funny you mention that Bill Jenkins was doing the same thing way back when using a dual point distributor he would disable a set of points in high gear to retard the timing.Ed Wright wrote: ↑Mon Oct 08, 2018 5:14 pmI have worked with most systems. I would be interested how you think one system is faster than another? Since 36 (for instance) degrees spark advance is 36 degrees, no matter which system is used. 13-1 A/F is 13-1, no matter which system is used. The new COPO Camaro race cars I have tuned came with the new Holley system. Not crazy about it, more limited than the FAST XFI that I use in my race car. Something I have done for years, and never had a car that did not respond to: More timing in low gear, back it up in second gear, and back it up to what it likes on the dyno in high gear. Long time friend Mike Edwards did the same thing in his Pro Stock car, using a programmable MSD Ignition box, that is illegal in my Supe Stock car. I can do it with the FAST XFI, but not a Holley. Talked to the Holley rep (wanted to try that in one of my friend's COPO. Holley rep says no, he never heard of doing that. Doesn't get out much, I'm guessing.Cutlassefi wrote: ↑Sun Oct 07, 2018 8:36 pmMaybe years ago but lots of better, faster stuff out there now from what I see.
I was doing that with my old '56 Chevy Jr Stocker. Three speed stick. Had a toggle switch mounted next to the Hurst shift lever, to turn the second set of points on (that is what retards it) when the shift lever went to second gear. Tripped the toggle switch, turned the second set of points on. Used a dual point 1958 Corvette dual point distributor, with the mechanical tach drive. Had one Sun electronic tach fail during eliminations. Grounded the coil - terminal, shut the car off. Had enough of that Stewart Warner had a mechanical tach. I switched to that.barnym17 wrote: ↑Tue Oct 09, 2018 5:31 amFunny you mention that Bill Jenkins was doing the same thing way back when using a dual point distributor he would disable a set of points in high gear to retard the timing.Ed Wright wrote: ↑Mon Oct 08, 2018 5:14 pmI have worked with most systems. I would be interested how you think one system is faster than another? Since 36 (for instance) degrees spark advance is 36 degrees, no matter which system is used. 13-1 A/F is 13-1, no matter which system is used. The new COPO Camaro race cars I have tuned came with the new Holley system. Not crazy about it, more limited than the FAST XFI that I use in my race car. Something I have done for years, and never had a car that did not respond to: More timing in low gear, back it up in second gear, and back it up to what it likes on the dyno in high gear. Long time friend Mike Edwards did the same thing in his Pro Stock car, using a programmable MSD Ignition box, that is illegal in my Supe Stock car. I can do it with the FAST XFI, but not a Holley. Talked to the Holley rep (wanted to try that in one of my friend's COPO. Holley rep says no, he never heard of doing that. Doesn't get out much, I'm guessing.Cutlassefi wrote: ↑Sun Oct 07, 2018 8:36 pm
Had to play with dwell settings on my Sun distributor machine to get 4 degrees retard. Solid 5 hundredths off my ETs. About that it gets me with this 350" LT1 automatic car I run now.
SS/JA 4156
SS/JA 4156
I'm not totally enamored with the Holley either.Ed Wright wrote: ↑Mon Oct 08, 2018 5:14 pmI have worked with most systems. I would be interested how you think one system is faster than another? Since 36 (for instance) degrees spark advance is 36 degrees, no matter which system is used. 13-1 A/F is 13-1, no matter which system is used. The new COPO Camaro race cars I have tuned came with the new Holley system. Not crazy about it, more limited than the FAST XFI that I use in my race car. Something I have done for years, and never had a car that did not respond to: More timing in low gear, back it up in second gear, and back it up to what it likes on the dyno in high gear. Long time friend Mike Edwards did the same thing in his Pro Stock car, using a programmable MSD Ignition box, that is illegal in my Supe Stock car. I can do it with the FAST XFI, but not a Holley. Talked to the Holley rep (wanted to try that in one of my friend's COPO. Holley rep says no, he never heard of doing that. Doesn't get out much, I'm guessing.Cutlassefi wrote: ↑Sun Oct 07, 2018 8:36 pmMaybe years ago but lots of better, faster stuff out there now from what I see.
I was really talking about the AEM Infinity. 400mips processor, add to that when coupled to their X series widebands you can't get any faster response, period.
http://dsportmag.com/the-tech/quick-tes ... band-uego/
Plus their timing control is some of the best and most accurate at this level, and even above. Hope this helps.
