Excessive oil pressure
Kevin Johnson
Re: Excessive oil pressure
Post by Kevin Johnson » Mon Oct 01, 2018 10:38 am
CGT wrote:
Mon Oct 01, 2018 9:43 am
That is a standard volume pump with a 3/4" inlet pictured, and that is what GM used from about 96 on.
The picture used was from Summit; here are a couple from Jegs:
https://www.jegs.com/i/Chevrolet-Perfor ... 7/10002/-1
versus
https://www.jegs.com/i/Melling/689/M155/10002/-1
CGT
Post by CGT » Mon Oct 01, 2018 10:53 am
versus
Yeah, also those are 2 standard volume pumps with .750 inlet. 93442037 from GM currently comes straight from GM with the Melling markings on it....standard volume pump
"How or Y do you think I get all this $hit, I read all of you all builds and desktop dyno them with all the correct info and I've got your build."
Kevin Johnson
Post by Kevin Johnson » Mon Oct 01, 2018 11:43 am
versus
You're very sure about that?
They are both listed as standard pressure but the one that costs $90 more is listed as high volume. That should be quite a scandal.
Edit: I just spoke with Jegs and they are very sure that the casting has been milled and bigger gears installed for the 93442037.
CGT
Post by CGT » Mon Oct 01, 2018 11:55 am
versus
The one listed from Jegs is being sold under GM part number, thus the reason for the price difference. That's not uncommon at all. And yes I'm certain. I have used 93442037 from GM in the past. The last one I ordered came in with the Melling number cast into the pump housing.....M155...so why pay the difference. You can even see the M155 casting in the pic of the GM part number. Jegs tech is incorrect :D
Kevin Johnson
Post by Kevin Johnson » Mon Oct 01, 2018 12:05 pm
Well, I am thinking that the GM spec for a high volume pump is different from what Melling produces and markets as their own high volume pump, using a different casting.
I know with Dodge Neon 2.0 oil pickups, the OEM piece has a cover and the Melling stock replacement doesn't.
Very interesting.
CGT
Post by CGT » Mon Oct 01, 2018 12:10 pm
And it may have been originally, like I mentioned the GM part wasn't always a melling m155 in the box, but it has always been a standard gear height, .750 inlet pump. It currently is identical though...spring and all.
Kevin Johnson
Post by Kevin Johnson » Mon Oct 01, 2018 12:33 pm
Here's a post from 2009:
https://www.corvetteforum.com/forums/showpost.php?p=1571657196&postcount=1 wrote: I need to buy an oil pump for my LT4. Due to the fact I'll be using the stock oil pan I can't use a high volume pump.
1. http://www.summitracing.com/parts/NAL-93442037/
This one is a high volume, standard pressure
2. http://www.summitracing.com/parts/NAL-12555884/
This one is standard volume, high pressure (60-70 psi)
The dealer tells me that #1 is the LT4 pump.
So which one is the one I can use that will not starve the pan or send too much oil pressure and perhaps break something?
Both pumps come with out the oil screen but Melling sells it.
GM no longer makes the oil screen
https://en.wikipedia.org/wiki/Chevrolet_small-block_engine#LT4 wrote: The LT4 was a special high-performance version of the new-generation LT1. With the addition of a slightly more aggressive camshaft profile, 1.6:1 roller aluminum rocker arms, high-flow intake manifold (painted red) with extra material above the port available to allow port matching to the raised port LT4 cylinder heads, it was rated at 330 horsepower (250 kW) and 340 lb⋅ft (461 N⋅m). It was introduced in the 1996 model year, for the last year of the C4 Corvette, and came standard on all manual transmission (ZF 6-speed equipped) C4 Corvettes. The engine was passed down to special versions of the Camaro and Firebird the next model year.
The LT4 was available on the following vehicles:
1996 Chevrolet Corvette when equipped with 6-speed manual transmission (includes all Grand Sports) (Production: 6,359)
1997 Chevrolet Camaro SLP/LT4 SS 6-speed (Production: 100 for the U.S., 6 for Canada. There were 2 prototypes)
1997 Pontiac Firebird SLP/LT4 Firehawk 6-speed (Production: 29)
All 135 production engines for the Firehawks and Camaro SS were completely disassembled, balanced, blueprinted and honed with stress plates. One in 5 engines was tested on a Superflow engine dyno and every car was tested on a chassis dyno in addition to performing a short 6-mile (10 km) road test.
Post by MadBill » Mon Oct 01, 2018 12:35 pm
Is it certain that the images are not the usual generic "representative" ones?
Kevin Johnson
Post by Kevin Johnson » Mon Oct 01, 2018 12:36 pm
Well, that is why I called Jegs.
Kevin Johnson
Post by Kevin Johnson » Mon Oct 01, 2018 12:39 pm
CGT
Post by CGT » Mon Oct 01, 2018 12:50 pm
The one in that pic has been in a vise! :lol:
Kevin Johnson
Post by Kevin Johnson » Mon Oct 01, 2018 1:19 pm
https://www.melling.com/wp-content/uplo ... atalog.pdf
Melling makes at least two different HV pump volume increases: 10% and 25%. A standard volume, 10% increase and 25% increase are all cited in their catalog as being addressed by this patent: https://patents.google.com/patent/US5810571A/en
I suspect that if the 93442037 from GM is measured it will be found to supply a 10% increase in volume.
Okay, now people can argue about whether 10% or 25% is better.
CGT
Post by CGT » Mon Oct 01, 2018 1:38 pm
The gm one in your pic will measure and flow the same as a m155 from melling lol (ITS THE SAME PUMP) . The 10 and 25 percent over pumps are a different series from Melling, they don't look anything like the GM pump. But ok. I currently am holding a 93442037 and a m155a in my hands.
Kevin Johnson
Post by Kevin Johnson » Mon Oct 01, 2018 2:56 pm
Yes, I know that they are for a different series of pumps by the patent application date. The point is that it would be simple for GM to specify an additional 10% in volume WHICH MAY NOT REQUIRE a different casting from Melling at additional cost thereby mollifying GM accountants.
If you are holding one, just disassemble it to be sure. Measure the gears. Directly compare them to the standard pump you have.
CGT
Post by CGT » Mon Oct 01, 2018 3:18 pm
Yes, they are the same...spring, gear height and all. Ive done this several times already in the past. I wouldn't have spoken up about it if I hadn't.
