carbon build up and flow numbers
rebelrouser
Post by rebelrouser » Sun Sep 16, 2018 5:54 pm
I want to ask what you guys think about carbon build up in cylinder heads and its effect on air flow. I know I do a lot of work on engines that people run for several seasons, and I wash the heads just enough to get the oil off and flow them with the carbon still in runners and chambers. I always see an improvement after they are cleaned before doing any valve work or further porting. Do any of you guys use a carbon cleaning product in your race engines? Motorvac and BG products both make a good cleaning system I have used on stock engines. A lot of the newer engines especially those direct injected engines have a lot of carbon issues.
David Redszus
Re: carbon build up and flow numbers
Post by David Redszus » Mon Sep 17, 2018 11:40 am
Just to add more crap to your bucket.
Consider the effects of hot carbon deposits in a running engine on air flow. The local heat changes the local air density and viscosity,
and therefore the air mass flow.
mag2555
Post by mag2555 » Mon Sep 17, 2018 12:36 pm
On the Exh side of the motor carbon scale and rust scale can add up to a reduction in flow real fast!
Take a look at this.
Here's the difference in flow from a Exh port that's only some 3.5 inches long.
All I did was use a 80 grit sanding roll to remove the carbon and rust, note in the pictures that I did not add polish anywhere.
If this much of a flow gain comes from just a port 3.5 inches long then think about what can take place in the tubes of a used header!
Flow @ 28"
.050--.100---.200---.300---400---.450---.500---.550---.600---.650
22.4---43.8--89.9---120.2--149.5-156.4--162.3-166.6--167.2
With clean up
22.5--44.2--91.5---128.4--153.5--161.3-167.2-174--177------180
GARY C
Post by GARY C » Mon Sep 17, 2018 1:18 pm
Does it increase or decrease temp? It seems it would insulate the runner from heat and the texture would help fuel atomization therefore cooling the intake charge.
I think you would have to do a before and after dyno test to find out it's effects.
Post by MadBill » Mon Sep 17, 2018 9:48 pm
Many years ago Smokey related a story about one of his engines mysteriously losing 20 HP during an all-nighter session. They finally realized that somewhere along the way they'd switched headers to a pair that was identical in every way, except for heavy rust deposits in all the tubes of the second set... #-o
GARY C
Post by GARY C » Tue Sep 18, 2018 12:03 am
When Lingenfelter was interviewed about his Pro Stock truck development he said that they polished and coated the inside of the primary tube on the step header. I don't remember is exact statement but it was measurable enough to do it.
Intake side may be a different story.
mag2555
Post by mag2555 » Tue Sep 18, 2018 7:10 am
If you ask me the Intake side reacts like my Exh side test does here, and Exh wise it's likely even far worse as a flow bench can not produce air at near sonic speed!
And yes I know the Intake ports do need texture for wet flow fuel issues.
