GREAT NASCAR V-8 dyno video
swampbuggy
Post by swampbuggy » Sat Sep 15, 2018 1:56 pm
Thought you folks who have not seen this video might enjoy it, notice the headers getting red/orange. Mark H
https://youtu.be/EScO0-NHGs0
JoePorting
Re: GREAT NASCAR V-8 dyno video
Post by JoePorting » Sat Sep 15, 2018 2:16 pm
That is one big water pump pulley.
Joe Facciano
Roundybout
Post by Roundybout » Sat Sep 15, 2018 2:43 pm
What were those green bar graphs on the bottom right, individual real time AFR meters? Interesting how much they moved around. I'm always very interested in seeing what they're monitoring.
cardo0
Post by cardo0 » Sat Sep 15, 2018 3:47 pm
Yeah, it looked more like a peep show. Funny they monitor A/F but not EGT. I did notice they monitor oil pan evacuation and blow-by.
swampbuggy
Post by swampbuggy » Sat Sep 15, 2018 5:32 pm
I noticed the pulley set up for the alternator.....man that alternator has to be spinning FAST. Mark H.
tjs44
Post by tjs44 » Sat Sep 15, 2018 6:06 pm
I was at TRD last year and watched them run a lap on the Sanoma road track.Very cool how they load and unload it for the turns.Tom
Post by MadBill » Sat Sep 15, 2018 6:23 pm
It's the diameter difference between the alternator and crank pulleys that determines its RPM.
Stan Weiss
Post by Stan Weiss » Sat Sep 15, 2018 6:31 pm
Interesting. Based on the SAE correction factor it looks like they use J1349. Is that what most are using now?
Stan
We have a package of more than 3025 DFW or FLW Files
pamotorman
Post by pamotorman » Sat Sep 15, 2018 7:49 pm
did Toyota copy the dodge engine since they were getting out of NASCAR. since ford and chevy were staying I can not see them allowing Toyota to copy their engines
swampbuggy
Post by swampbuggy » Sat Sep 15, 2018 8:37 pm
Pamotorman...there is not very much difference in Chevy, Ford, Toyota, or Dodge as far as the parts that actually make the horsepower is there ??
Madbill...I see that the water pump is under driven (typical) BUT still....that alternator must be turning faster than normal stuff (detroit). Mark H. :)
Post by MadBill » Sat Sep 15, 2018 8:52 pm
You're right; it looks like about 2:1, so close to 20,000 RPM max. Seems like way more than needed and well beyond the safe upper limit for most units. :-k
Charliesauto
Post by Charliesauto » Sat Sep 15, 2018 9:01 pm
That's a high end Bosch alternator, dual cooling fans, lots of ventilation in the housing. Bosch recommends the pulley sizing should achieve 20,000 alternator shaft rpm at max engine rpm. They actually last longer turning this rpm because they run cooler.
These alternators are around $2,500 ea.
Warp Speed
Post by Warp Speed » Sun Sep 16, 2018 8:36 am
The inertia dyno.......
Bald guy with glasses appears to be Reggie Hart?
Former Hendrick and DEI guy.
GRTfast
Post by GRTfast » Sun Sep 16, 2018 9:28 am
Man that thing screams.
swampbuggy
Post by swampbuggy » Sun Sep 16, 2018 10:29 pm
Warpspeed, is that similar to a pull you guys would do at HMS ? What i am wondering mostly IS, would the pull be that slow and long ??? Also, is that way of pulling an engine typical of an inertia dyno ??? Thanks Mark H.
