Dart SHP Block
perfconn
Dart SHP Block
Post by perfconn »
Anyone know if there is enough material around the lifter bores in a sb chevy Dart SHP Pro block to allow boring them out to use the Jesel .937 keyway lifters?
perfconn
Re: Dart SHP Block
Post by perfconn »
Anyone with experience on this?
af2
Re: Dart SHP Block
Post by af2 »
WHY?
GURU is only a name.
cgarb
Re: Dart SHP Block
Post by cgarb »
Maybe he has a bunch of Jesel lifters...what should it matter why?
JoePorting
Re: Dart SHP Block
Post by JoePorting »
Dart would give you the most accurate answer.
Joe Facciano
Charliesauto
Re: Dart SHP Block
Post by Charliesauto »
perfconn wrote: Thu Sep 13, 2018 6:20 pm Anyone know if there is enough material around the lifter bores in a sb chevy Dart SHP Pro block to allow boring them out to use the Jesel .937 keyway lifters?
That's a 1.062" OD bushing, there is plenty of material.
perfconn
Re: Dart SHP Block
Post by perfconn »
Just had an SHP block done by Clements and it worked fine.
BILL-C
Re: Dart SHP Block
Post by BILL-C »
About 5 years ago we had to fix a sbc iron eagle block that had excessive oil to top end on one bank only. When lifter bores were opened up for 1.062 od bushings they broke into main oil galley. We fixed issue with custom bushings that had only partial od oil band. It wasn't a SHP block, but look for issue anyways.
Carlquist Competition Engines
