camshaft spec
hjallle123
camshaft spec
Post by hjallle123 »
hi
i wonder what this camshaft would be god for ( its a sbc cam )
lobe sep 114
intake centerline 110
dur @ 050
int 284
exh 292
lobe lift 0.470 intake
lobe lift 0.460 exh
thanks
prairiehotrodder
Re: camshaft spec
Post by prairiehotrodder »
a high compression, high rpm big cube motor ?
RevTheory
Re: camshaft spec
Post by RevTheory »
4.155 bore x 3.5 stroke
6 inch rod
2.10 x 1.6 valve 18* heads
14.5 compression
9,000 rpm
:D
user-17438
Re: camshaft spec
Post by user-17438 »
RevTheory wrote: Thu Sep 13, 2018 6:49 pm 4.155 bore x 3.5 stroke
6 inch rod
14.5 compression
9,000 rpm
:D
I'd want a valve closer to 2.2 and more compression.
Peak around 8300
