2 * 1050 dominators on sbc 18 degree engine
- New Member
Hi
will 2* 1050 dominator carbs be to big on a 406 cbc 18 degree engine with sheetmetal intake
rpm 8200
stall speed 6700 rpm
810 hp
car 2465 lbs
rear 5.67 gear
powerglide 1.76
rpm 8200
810 hp
car 2465 lbs
rear 5.67 gear
powerglide 1.76
Re: 2 * 1050 dominators on sbc 18 degree engine
Here is a ford with a pair but rpm is much higher
Anything can work, pretty sure you'll need more converter, 7200 or so. My concern is it might be lazy to accelerate if held back with a (relatively) tight converter and 2 speed tans.
Years ago, NHRA Pro-stock truck ran 18-degree SBC's with dual dominators. I believe Dan Davinci was a big player in those during that era. He just completed a set for me on a personal 434 SBC, sheet metal TR drag engine that I should be finishing soon. You may reach out to him. I believe the phone number on his web site is also his cell phone, 281-964-7782
Brandon
Brandon
- New Member
they have been sitting on a 358 prostock truck before
- New Member
Here's a personal build. I plan on measuring for pushrods this weekend.
- New Member
how big is that engine ? bore and stroke
rpm ? horsepower
rpm ? horsepower
- New Member
Now I need a better pic of that fine "BowTied Beauty" in the background. I may be biased but that looks good what we can see! LOL! Harry
4.155 x 4.0, Bryant crank, Little M, Titan pump, .903 Jones Roller, Bowtie 363's with Hut 1 CNC flowing 374 @ .800, M&M intake, 14.46:1hjallle123 wrote: ↑Thu Sep 13, 2018 9:04 pm how big is that engine ? bore and stroke
rpm ? horsepower
Plan to dyno later this fall.
- New Member
here it is
Glidden ran 2 dominators on his 337" engine in pro stock.
