Large Vortec bowtie, Engine?
F-BIRD'88
Re: Large Vortec bowtie, Engine?
Post by F-BIRD'88 » Mon Sep 24, 2018 2:33 pm
U seem to want to talk about it rather than do the obvious and low cost stuff too.
6.50camaro
Post by 6.50camaro » Mon Sep 24, 2018 3:14 pm
Fel Pro 1003 can be found for under $35 each or if you unshroud the valves and open the chambers up the .024 steel shim gaskets are under $15 each from Speedway motors . Most of their own line off gaskets are ok and cost a lot less than name brand stuff. Dan
F-BIRD'88
Post by F-BIRD'88 » Mon Sep 24, 2018 5:47 pm
Use the felpro 1094 steel shim gasket (..015" …)
88bluestar
Post by 88bluestar » Thu Oct 04, 2018 1:21 am
What's your take on possibly running 1.3 roller rockers on the exhaust? Would it help build cylinder pressure, and increase torque. 1 3/4 primary headers, open exhaust
CGT
Post by CGT » Thu Oct 04, 2018 9:06 am
If you look on my "Special Needs" thread, I did a little testing with 1.3 rockers on the exhaust of it. It was kind of interesting
"If you pick up a starving dog and make him prosperous, He will not bite you. This is the principal difference between a dog and a man"
GARY C
Post by GARY C » Thu Oct 04, 2018 10:52 am
CGT, do you think that would still be the case with a shorter ex duration?
CGT
Post by CGT » Thu Oct 04, 2018 11:09 am
Maybe, maybe not. I guess it really depends on which one of the things that the different ratio changes, caused the power gain/loss. Did it like less peak lift, less area, or did it maybe just like coming off the seat slower....hard to say.
88bluestar
Post by 88bluestar » Thu Oct 04, 2018 3:30 pm
Maybe i read the wrong post but couldnt find the info on running the 1.3 rockers.
GARY C
Post by GARY C » Thu Oct 04, 2018 4:03 pm
It will be interesting to see what development comes from the ex side over the next 10 years, although most will probably keep it under their hat for a while.
CGT
Post by CGT » Thu Oct 04, 2018 4:14 pm
Maybe I didn't post that. I don't feel like sifting through it all to find it. :D Do you have Excel?
