evening fellas,
looking to get my hands on some OEM spring retainers for a 1977 351 modified. not having any luck with my usual parts supplier, and the dealership can't do anything for me either.
any suggestions?
ford 351M oem retainers
Re: ford 351M oem retainers
Are the valves single groove intake and exhaust or single grove intake multigroove exhaust
https://www.ebay.com/itm/Ford-OEM-Valve ... -NOS-E43Z- 6514-A-80-89-2-3L-HSC-3-8L-89-95-/231291835631
Dave B
This is on Epayhttps://www.ebay.com/itm/Ford-OEM-Valve ... -NOS-E43Z- 6514-A-80-89-2-3L-HSC-3-8L-89-95-/231291835631
Dave B
LIGHT 'EM UP
Use a 460 ford retainer
They are close to the same installed height and are for 11/32" stem valves.
They will work with standard or multi groove locks. I use them from time to time when a stock steel retainer is all thats needed. Or when rules say stock retainer only up to 500 Lbs open pressures.
thanks pro-power.
1968–1997 385 V8—big-block (370/429/Boss 429/460/514)
is that the engine you speak of?
