Horsepower ratings are based on the fact that y'all keep asking........
I rate one rod at 500 HP. I've run it at 1725, with an 8740 bolt.
We just don't want to get sued any more often than is absolutely necessary.
What set of SBC 6.0 rods has the best cam clearance for 383
Re: What set of SBC 6.0 rods has the best cam clearance for 383
Sort of like you buy a claw hammer and find a label on it that reads: "Caution. May contain nuts or nut products." (Yes, the handle might be hickory...) Ya can't be too careful in retail sales.
- af2
Bill!!!
I am having a hard time buying parts for the race car in California because of prop 65!!! May contain styrine!!! Like I'm going to smoke it?
GURU is only a name.
- af2
Back to the OP... I used the Scat PC rods with the LT4 cam and had to relieve .060" on 2 rods. Was not a big deal.
Compstar 6" rods with a 3.875 crank hit my .425 lobe standard base circle. I've seen others on this forum complain that they don't clear as much as advertised.
