What set of SBC 6.0 rods has the best cam clearance for 383
bigmike
Post by bigmike »
Trying to get away from using small base circle cam on SBC 383. What set of SBC 6.0 rods under $750 a set would help me achieve my goal. I been looking at the Compstar H beam, Manley H beam, Scat Pro Comp, lunati voodoo stroker rods 70160003-8 (hard to come by right now 1 to 3 months away)., also not opposed to using something like Howards Cams Precision Dense Forged Connecting Rods PPF6000 in this engine if they get me cam clearance needed. Thanks all.
77cruiser
Re: What set of SBC 6.0 rods has the best cam clearance for 383
Post by 77cruiser »
Jim
SupStk
Post by SupStk »
Callies has a set of stroker rods that will clear in a 434. The under $700 will leave the ones I'm thinking of out.
The Scat I-beams are HP limited. You need to check for clearances while trial assembling the engine no matter who's rods you end up buying.
Monty Frerichs
B&M Machine
PackardV8
Post by PackardV8 »
Is it going to be a 450hp 383" or a 650hp 383"?
bigmike
Post by bigmike »
PackardV8 wrote: Tue Sep 11, 2018 6:57 pm
Around 475 - 525 HP
77cruiser
Post by 77cruiser »
Scat is plenty good at that HP.
Jim
PerfTech
Post by PerfTech »
Look at Molnar Tom has some very good rods they will clear with no problem give him a call
mtrhead
Post by mtrhead »
I have std 6.0 skat I beams. 3.810 stroke crank (old sprint car crank) std base circle cam. Been running for years no issues.
Orr89rocz
Post by Orr89rocz »
I had compstar h beams that cleared a .400 lobe easily. Dont know how much room they have for bigger tho but seem good
bigmike
Post by bigmike »
mtrhead wrote: Tue Sep 11, 2018 8:36 pm I have std 6.0 skat I beams. 3.810 stroke crank (old sprint car crank) std base circle cam. Been running for years no issues.
Thanks you wouldn't happen to know what version of the Skat I beam you used? Scat has three different versions of their I beam rods.
bigmike
Post by bigmike »
Orr89rocz wrote: Wed Sep 12, 2018 10:54 pm I had compstar h beams that cleared a .400 lobe easily. Dont know how much room they have for bigger tho but seem good
Thanks that is good information, the Compstar h beams are high on my list.
ProPower engines
Post by ProPower engines »
bigmike wrote: Thu Sep 13, 2018 12:40 pm
The best option for scat is the 26000716 for a 6" and a 25700716 for a 5.7 rod.
They are a profiled bear and will clear most cams used in a 350 block.
kimosabi
Post by kimosabi »
6" Scat H beams here, 3.75 crank and .360 lobes. 1.140 base circle. Good clearance.
mtrhead
Post by mtrhead »
Scar pro-series. 7/16 bolts 6.00. 2.100. Bushed
BLstangin
Post by BLstangin »
another vote for the scat pro 7/16 rod, had them in a 715hp 408 Cleveland and never broke them shifting at 7,600 rpm. They will be fine, also used a set in a 383 for a boat with a standard base circle hydraulic roller cam, no issues clearing the cam. That motor made 370hp/460 ft/lbs and spends hours on end at 4,000 rpm pulling kids on a tube.
70 mustang coupe restored with the help of my Dad and LOTS of friends. 306 490hp/398ft lbs t56 magnum 5.00 gear
1986 F150 standard cab short bed build in progress!
