Ignition wires with Sanderson headers
I'm wondering if anyone is using Sanderson headers with this pipe configuration. What are you using for ignition wires. Regular 90 degree spark plug boots wont clear the top pipes. Any help and part numbers would be greatly appreciated.
79 Cmaro, 427 sbc, Tunnel Ram Dual Quad with Eddy carbs, AFR 210 Race Ready heads, 263-272 @.50 Comp solid roller cam, 4.10's and a faceplated Tremec TKO 600.
65 Beaumont 406 tunnel ram faceplated TKO600
Re: Ignition wires with Sanderson headers
Is there room to go under the headers? that usually solves alot of problems..
I'm going to give it a shot this weekend
Thanks
Thanks
