not guess the hp but guess the ET??
AMXstocker1
Post by AMXstocker1 » Fri Aug 31, 2018 9:45 pm
We have a new combination that lacks 2 an lines from being done and it will be tested next weekend this coming weekend so i thought i'd post specs and pics and see if anyone wanted to guess et and mph and i might send the closest person a hat or something small who knows but heres the combo
1969 AMC AMX
3160lbs
mopar 8 3/4 with spool and 4.56 gear
28x10.5 mickey thompson pro bracket radial
727 torqueflight with a brake and 8 inch a 6400 rpm converter
aerospace brakes on all 4 (probably no difference)
Calvert monoleafs and bars and single adjustable shocks on rear
double adjustable vikings on the front with limiters this will take a bit of dialing in
engine
418ci 4.185x3.800 with 6.125 rod
indy heads filled to just under 230ccs and angle milled 54cc chamber
flow 328 @ .700 and at 300 by .500
15.5 to 1 compressing
Herman lewis intake and a 950cfm 4150 on e85
cam is a solid roller
lift is .773 intake and .745 exh
dur @ .050 273int and 287exh
lobe center is 110.0 and installed at 108.0
headers are custom 1 7/8s to 2inch stepped with a megaphone style merge collector that go down to 2.75inchs and open back to 3.5inch
motor is nuetral balanced
aerospace vacuum pump we plan on setting at 12inchs.
i think that rounds it out.
i guess i'll mention the last motor in the car went 6.75 at 101.00
and it was a 9.5 to 1 433 inch motor with lightly breathed on indy heads that flowed 290
and .608 lift solid flat tappet that was 257 and 264 @.050 on a 108 lob center. with some 1 7/8ths hooker headers
amc fan
Re: not guess the hp but guess the ET??
Post by amc fan » Fri Aug 31, 2018 10:08 pm
Who spect out your cam? Way too much exhaust duration in my opinion.
amc fan
Post by amc fan » Fri Aug 31, 2018 10:10 pm
AMXstocker1
Post by AMXstocker1 » Fri Aug 31, 2018 10:12 pm
A.H. adkins
prairiehotrodder
Post by prairiehotrodder » Fri Aug 31, 2018 10:25 pm
6.30 at 109 mph.
Thats my best guess.
6.50camaro
Post by 6.50camaro » Fri Aug 31, 2018 10:35 pm
I'll take a shot 1.40- 60' 6.35 @108 .Don't know much about amc motors but love those AMX 's. Dan
AMXstocker1
Post by AMXstocker1 » Fri Aug 31, 2018 10:42 pm
It went 1.43 with the last motor and it will see 1/4 mile action too the last motor only did once and it went 10.89 coasting through because too much gear for the little streetmotor that was also the first pass on that engine. But if it runs close to your guess's ill be real happy and your about where i am on guesstimates.
Casper393W
Post by Casper393W » Fri Aug 31, 2018 10:56 pm
I think it's going to run... It should hit the tires alot harder and I'm willing to bet you will see a 1.3x 60'.
I too wonder about the exhaust duration.... Seems a bit excessive.
Andy
406shark
Post by 406shark » Fri Aug 31, 2018 11:00 pm
I'll take a guess...
First pass off the trailer... 6.43 at 107 and change.
By the end of the day... 6.37 at 108 and change.
Jeff
Casper393W
Post by Casper393W » Fri Aug 31, 2018 11:04 pm
You might not like this... I would swap in a Glide.. you are getting into the world where you will have too much SLR... It will want to stand on the bumper or blow the tires off depending on front end travel
In my 304" 2V Mod motor 96 mustang when we're running 6.0's -5.90's we swapped out the C4 trans for a Glide with a Greg Slacks converter and we picked up a tenth and a half!!!! The car was waaay more consistent because it calmed it down off of the hit.
AMXstocker1
Post by AMXstocker1 » Fri Aug 31, 2018 11:09 pm
Im not against a glide its just not in the budget at the moment, od really like to put a 2.10 gear set on 727 from protrans but its going to take some time we might try to pull sometiming off the hit but first well see of we can make the chassis work.
geraldtson
Post by geraldtson » Sat Sep 01, 2018 9:37 pm
Same time 6.75 at 101.00 I think you'll get it faster later on,but i believe first night out will about same as old combo! Let us know!!
amc fan
Post by amc fan » Sun Sep 02, 2018 2:48 pm
I have a similar set up 12 to 1 CR---4.185"X 3.8" stroke indexed reground 401 crank, Eagle 6.125 H beams for SBC narrowed,this assembly will be Internally balanced,just taken out of grinder this week. Indy SR heads ported not filled Flow specs are .500" lift Intake 305 cfm,.600" 325 cfm,.700" 336cfm .800 340 cfm......exhaust=.500" 214 cfm,.600" 233 cfm ,.700 252 cfm ,.800 263 cfm, HLR intake welded & modified, 850 cfm carb ,---Mike Jones roller bracket cam 272/279 @110 c/l .681" lift. One of the AMC super stockers asked if I have 390 cranks for sale ...well yes I have some index ground used ,untouched used,used with installed Torqueflite hubs, machined and installed.... half a dozen new old stock with bearings,nos with hubs machined and installed, and I make,sell and install the hubs if there is any interest.
paulzig
Post by paulzig » Sun Sep 02, 2018 9:31 pm
660 Foot 6.22
660 MPH 109
1/4 Mile ET 9.86
1/4 Mile MPH 135
AMXstocker1
Post by AMXstocker1 » Mon Sep 03, 2018 11:33 am
Amc fan thats a nice setup we run a local headsup class that requires a 230cc or less intake runner and a 950cfm carb. If the class goes away we will send the heads back and have the epoxy knocked out and they should be in your neighborhood after that. I like your cam specs i wouldve went more lift and these heads are so good on the exhaust side i question the big exhaust duration but it s a father son project and he want to let adkins spec the cam.
