I have talked a little about this deal before on her but now I have settled on a platform and have most of the parts worked out. What I am looking for from all the massive brains here on this forum is if I am correct in my thinking or if there are things that I should be doing different.
First the application is extreme endurance racing. periods of around 40 min at wot are not uncommon. Cooling is not an issue as it is in a boat. The class I am in dictated less than 260 ci if I am forced induction.
What I am thinking
GM ls9 block(it comes with oil squirters and larger head bolts form factory, is alum and rated for at least 900 hp)
bore would 4.065 x 2.5 stroke (only because the block is 4.065)
Mast 285 cc head with inconnel valves and shaft rockers
camshaft hydraulic roller .650-.700 lift 245 ish dur
Vortech v30-94 a super charger running 15-20 lbs boost
oiling system I am going back and forth from a daley dry sump to just a good wet sump.(piston speed is only 3100 at 7500rpm and not sure how much windage with only 2.5" stroke.
fuel I am planning on running is e85 with Holley fuel injection.
Need help with this unique combination.
Re: Need help with this unique combination.
With that short of a stroke why not use a low deck ford block. You will have a terrible rod ratiojet1 wrote: ↑Wed Aug 22, 2018 2:36 pm I have talked a little about this deal before on her but now I have settled on a platform and have most of the parts worked out. What I am looking for from all the massive brains here on this forum is if I am correct in my thinking or if there are things that I should be doing different.
What I am thinking
You could always use a 90degree Chevrolet 6 as the platform.
Roughly the same price and and 150lbs heavier plus would need to machine in oil squirters for it to viable.exhaustgases wrote: ↑Wed Aug 22, 2018 3:18 pm Some idea's, I'm sure others will have better ideas.
https://www.jegs.com/p/Dart/Dart-LS-Nex ... 3/10002/-1
https://www.jegs.com/p/Chevrolet-Perfor ... 2/10002/-1
https://www.jegs.com/p/Chevrolet-Perfor ... 6/10002/-1
I have discussed that with some piston guys at mahle and was told it was not an issue at my rpm and with forced induction.MTENGINES wrote: ↑Wed Aug 22, 2018 3:37 pmWith that short of a stroke why not use a low deck ford block. You will have a terrible rod ratiojet1 wrote: ↑Wed Aug 22, 2018 2:36 pm I have talked a little about this deal before on her but now I have settled on a platform and have most of the parts worked out. What I am looking for from all the massive brains here on this forum is if I am correct in my thinking or if there are things that I should be doing different.
What I am thinking
The Ford would work but the sytems that I have and for parts availability from other racers to borrow if needed( starter ,alt , coils,ets) the lS is a much better choice for me.MTENGINES wrote: ↑Wed Aug 22, 2018 3:37 pmWith that short of a stroke why not use a low deck ford block. You will have a terrible rod ratiojet1 wrote: ↑Wed Aug 22, 2018 2:36 pm I have talked a little about this deal before on her but now I have settled on a platform and have most of the parts worked out. What I am looking for from all the massive brains here on this forum is if I am correct in my thinking or if there are things that I should be doing different.
What I am thinking
There is a host of 6 cylinder engines I could use but in order to keep simpler and parts availability to borrow if needed from other racer an LS is the best.
Well if you are set on this combo. What is your question?
Yes my question is not what block to use per say, it is mostly regarding, heads, do I need to run a dry sump, thoughts on being able to run a hyd roller cam, are there quench issues running 20lbs of boost, valve spring cooling,
