Moroso 21237
Re: Moroso 21237
So does my pump. Good to hear another's positive experience with the style pump. My pan is a modified Moroso 20183 8.25", what depth is yours?
Re: Moroso 21237
Probably:
The oil rushing forward at the end of the run gets churned by the rotating assembly and rapidly dispersed across the surface of the oil the length of the pan. The shelf that you constructed delays the returning oil and gives the antifoam a chance to break the larger surface bubbles (so the residency time of the oil fraction above the baffle is increased). Smaller bubbles persist longer and are still drawn into the pump lowering the pressure.
When you experiment with solvents in the pan, tilt the pan forward by 45 degrees to simulate just 1g of braking. I suggest the solvent used be water because you'll probably flood the floor.
Re: Moroso 21237
It goes down to 20lbs, I have heard that is not going to be a problem, from a few sources. I guess I'm just being anal. My own car has a 79 dollar eBay street/strip 7qt pan with zero loss of pressure in the shut down. That's what is frustrating to me. One would think Moroso selling a 800 dollar oil pan would test for things like this. It's not my money that paid for it, but it's still aggravating that it don't work well.
Re: Moroso 21237
Rod bearings can survive without damage up to 25% aeration; mains 50%. Can does not mean always will.
Re: Moroso 21237
I plan to pull the engine this winter and look things over. Depending how the bearings look I will rethink the oiling system as needed I guess. It's an expensive engine and I just am being paranoid I guess because it's not mine.
Re: Moroso 21237
I went back to my references to make sure accurate info is being given (it should have been 30% for the rods but note the caveat about testing conditions); here is my source:Kevin Johnson wrote: ↑Tue Oct 02, 2018 2:19 pm Rod bearings can survive without damage up to 25% aeration; mains 50%. Can does not mean always will.
Re: Moroso 21237
Before you tear it down again I would try a pass with an additional half quart of oil in it. You never know until you try.
