Bad one
Racer18
Bad one
Post by Racer18 »
ImageI think we can save the intake...😳
lefty o
Re: Bad one
Post by lefty o »
a little duct tape, and she'll be good as new!
RevTheory
Re: Bad one
Post by RevTheory »
Just a flesh wound :D
Way to over-achieve though!
Racer18
Re: Bad one
Post by Racer18 »
Rods still spin free and not a scratch on the cam!
cgarb
Re: Bad one
Post by cgarb »
Something happened to the piston I assume?
bigmike
Re: Bad one
Post by bigmike »
Owie! That hurts looking at.. Looking at the rod, did it loose a valve or what happened?
peejay
Re: Bad one
Post by peejay »
Friend of mine did that on a Mazda 1.8 engine. The #1 rod sawed through both sides of the block as well as the main cap girdle, pickup tube, and oil pan. Engine was still running after it happened although it was a little rough :)
The interesting thing is, when he went to sell the remaining three rods and pistons, it turned out the other three were also bent. The chunk of rod still on the #1 journal would spin freely although it could not be removed because the nuts/bolt ends were too beat up.
1972ho
Re: Bad one
Post by 1972ho »
Way to much NOS,that rod knock the hell out that block,I had a rod break off around that area but it did nothing to block I had a crank scraper and it was only bent upwards.
Dave Koehler
Vendor
Re: Bad one
Post by Dave Koehler »
#8 rod was just confused.
F-BIRD'88
Re: Bad one
Post by F-BIRD'88 »
Takes pcv to a whole new level.
superpursuit
Re: Bad one
Post by superpursuit »
Got any super glue? :)
Racer18
Re: Bad one
Post by Racer18 »
Circle track engine. No power adders. Had head repaired on that cylinder, I think weld leaked. Hydraulic. Boom. Sucks either way
Kenova
Re: Bad one
Post by Kenova »
Nice main caps.
Shame about the block.
400?
Ken
Over the hill but still learning!
Retaining it is the hard part.
Racer18
Re: Bad one
Post by Racer18 »
Dart SHP Roller cam bearings. Shame.
midnightbluS10
Re: Bad one
Post by midnightbluS10 »
exhaustgases wrote: Fri Aug 17, 2018 9:12 pm 540 Rat was right.
About?
JC -
