Mag on the street?
Mag on the street?
Got another question for you all. I have a nice Mallory Sprint Mag III, will they hold up on the street? I bought this for a blower set up and didn't use it, Spud Miller has suppresion wires he said that'll work good, only thing that might give me a problem is the my vintage Dixco tach but I think Spud has a set up where I can use it. I'd sell it and go MSD but I doubt I'd get my money back out of it. I ran a Vertex on the strip years ago but that's the only experience I've had with them.
Re: Mag on the street?
I've never heard of a spring mag 3, sprint mag 2 yes, super mag 3 yes. I'm not sure I'd try a super mag 3 on the street, sprint mag should be fine. Suppression core wires don't last long with a mag.
-Carl
-Carl
The 3 has the rare earth magnets from the research I've done, that's one reason why I figured it'd be ok. According to Spud at Fuel Injection Enterprises his wire will. I have no experience so I can't say, I thought you had to run solid core with all mags until I talked to him.
I started playing with engines late 60s if my memory is right solid core wires showed up early 70s in the speed shops. The mags before that time used on everything from bonneville to blown drag cars were they not using supression wires ?.
No. Solid wire plug wires were around since the beginning of spark ignition. Resistance wire showed up in the '50s with graphite coated string in rubber insulation.Little Mouse wrote: ↑Thu Aug 02, 2018 10:52 pm I started playing with engines late 60s if my memory is right solid core wires showed up early 70s in the speed shops. The mags before that time used on everything from bonneville to blown drag cars were they not using supression wires ?.
Model A Ford spark plug "wires" LOL
Friend of mine had 56 Chevy old school gasser he tried one on bbc for two summers of cruising and nostalgia racing...always fouled plugs even with very tightly gaped plugs.
Changed out to a converted vertex mag to keep the look but internals changed to distributor...used with msd box and no more fouled plugs...ran great!
- New Member
I've run a Don Zig prepped Vertex mag for years in a 600hp SBC street car.
Upgrading to the rare earth magnets seemed to make a big difference. I run 10mm Taylor stainless core wires and the recommended plug gap.
